It is currently Wed Oct 21, 2026 10:07 pm
PostPosted: Sun Jul 12, 2026 11:58 pm
Car Model: '69 Dart Custom
What could this hole be for? It's been found on a newly installed '74 head. Does not exist in my older '69 head.
When filling my rad, coolant started dispensing out of it and into the lifter galley :o
It's threaded, and I plugged it with a small screw + teflon tape...
Any ideas?
PostPosted: Mon Jul 13, 2026 2:19 am
Oh, I'm sorry! I drilled and tapped that hole in about 2004 to mount part of an EFI fuel rail and forgot it was there and that you needed to plug it. At least it was an easy fix.
PostPosted: Mon Jul 13, 2026 9:36 am
No worries! :D
PostPosted: Mon Jul 13, 2026 1:42 pm
That is a top secret nitrous injection port. Lou is very sneeky!! :D :D
PostPosted: Mon Jul 13, 2026 11:43 pm
Custom bleed valve for purging air out of the cooling system. :wink: 8)
PostPosted: Tue Jul 14, 2026 9:27 am
Yes, it also is a perfect location for cooling system bleeding, although I've almost never had trouble with that...
PostPosted: Tue Jul 14, 2026 3:46 pm
That is a machined boss for something. I've seen various sensors mounted there on newer ones. Mostly ones that originally had lean burn ignition.
Users browsing this forum: Bing [Bot] and 26 guests
