It is currently Wed Sep 30, 2026 1:50 am
PostPosted: Thu Aug 29, 2013 9:41 am
Brand new OE turn signal switches are back!
These are newly made according to the final-revision Chrysler blueprint, by an original supplier to Chrysler. These are not the crude, poor-quality Chinese knockoffs available all over the place, and they are not the Shee-Mar parts that kindasorta fit and fail early and often; they are the real deal – they fit and work all the way correctly, and they have the correct snap/click switch operational feel.
Three types are available (two types pictured; will add third-kind pics ASAP. Click any pic for larger):
• With split-flat-spade Packard terminals for '62-'63 cars
(part № 2258 700)
• With "Twin-Lock" box-and-point terminals for '64-'67 cars
(part №s 2631 383, 2496 163, 2822 170, 2857 241)
• With "Twin-Lock" box-and-point terminals and "upside down" orientation of wire attachments at switch body,
for '68-'69 cars (part № 2857 241)
Applications are A-bodies, B-bodies, and C-bodies, and (some) Imperials without tilt steering column.
A loose and sloppy, worn-out old switch is a pain (no click-snap into position, no self-cancelling, wondering if both your brake lights will work today…). Spend endless money-time-effort on repeatedly-failing poor-quality ones, spend a mountain of money on a new old stock switch…or buy one of these new-new-stock switches off me for $129.82 + $13.18 postage within the lower 48 states = $143.00, USD.
Shipping (from Michigan) by Priority Mail, within the US, usually takes about a week. Postage to other locations on request. Please send me a PM.
About that horn contact:
These switches have the solid-copper brush type of horn contact, rather than the roller wheel. This might make you squawk, and it's understandable why: a lot of the crummy-quality switches have a poorly-made version of the solid brush, and because that's a visible difference to the old-production OE switches, it came to be associated with the crummy ones, and people came to look out for the solid brush as an indicator (zing!) of a switch to avoid. Also, it's not common knowledge that when installing a switch with the solid brush, you apply appropriate lubricant to the contact ring on the back of the steering wheel so there won't be any noise made as the brush slides on the contact ring, so people would install them dry, and then when they heard noise from it, they'd decide that meant the solid brush contact is no good.
There's nothing wrong with the brush-type horn contact, if it's made well and installed properly. Chrysler themselves phased out the roller wheel and went to the solid brush in the early-mid '70s on all OE turn signal switches, and Mopar replacement switches came with a sheet advising the installer to apply a thin film of lube to the contact ring:
For awhile, the Mopar switches came with a little capsule of appropriate lube, a graphite grease. I don't have any such capsules, but graphite grease is easy to buy, or you can make some by mixing regular graphite powder into regular white lithium grease. Or dry graphite-film spray would do the job. Or heck, if I had none of the above and needed to install a switch in a hurry, I'd grab a regular № 2 pencil and apply it all over the contact ring, then assemble it and drive off. The need here is just for something slippery and conductive.
The Chrysler blueprint for these '62-'69 switches has provisions for either type of setup, roller wheel or solid brush, and the horn brush assembly in my switches is really nicely made: appropriate diameter slug of good copper, chamfered so it won't chatter; good, lively fully-enclosed spring, precise fit of the brush within its sleeve so it won't bind, etc.
And after all that, if you still have doubts about it, I guess there are two good answers:
• There are brushes and not roller wheels in your alternator, starter, blower motor, and wiper motor.
• These are still the best switches on the planet for this application.
PostPosted: Fri Sep 13, 2013 8:08 am
Dan, can you post a link to an exploded assembly diagram for these? I cant figure out one washer setup. My return action on the fingers is too tight, or sloppy loose. I think I missed a fiber washer or something. I rehab'd it so long ago that its not fresh in my old mind anymore.
PostPosted: Wed Oct 16, 2013 6:04 am
Do you have the switches for '61-'68 trucks?
PostPosted: Wed Oct 16, 2013 10:06 am
I don't have switches for the '61-up trucks, no. And the switches are not meant to be taken apart -- if one is disassembled to the point an exploded view diagram is wanted, it probably will not successfully go back together. Keep in mind, the action on the switches before the "lane change signal" feature was introduced is supposed to be a very positive snap/click into place. It's a big (and sometimes alarming) change from the sloppy action of a worn-out switch, but it's normal -- though the switch should not bind; if it does, slightly loosen the screw that holds the turn signal lever to the switch.
PostPosted: Thu Jul 03, 2014 5:59 am
I have one of these in my 62 Valiant and am pleased with it. It installed easy and works perfect!
Dave
1972 d-100 parts truck
 Post subject: OE Turn Signal Switches
PostPosted: Tue Nov 01, 2016 2:00 pm
Car Model: 1965 Dodge A100 Pickup w/Super Six
I have an '65 A100 Pickup. Would these turn sig switches work for my ap? Do you still have them?
 Post subject: I am ready for one
PostPosted: Tue Jun 13, 2017 12:49 pm
Dan, I am ready to order the switch. how do we do it?? $105 to your Paypal?
66 dodge dart 270, 225ci, 3.7l, L6
PostPosted: Tue Jun 13, 2017 1:16 pm
I'll send you a PM. Anyone else who wants one: Please send me a PM.
PostPosted: Tue Feb 06, 2018 8:59 pm
Car Model: 1968 barracuda slant six 4speed super charged
Id like one for my 68 a body barracuda.. I live in Seattle.. can i meet you and pick
One up? Thanks
Brian Loewes
PostPosted: Tue Feb 06, 2018 9:33 pm
Hi, Brian. Send me a PM and let's work it out.
PostPosted: Thu Jan 19, 2023 10:58 am
Dan, can you get those OE turn signal switches or are they long gone??? I'm used to the regular keep-it-screwed-in and right-turn-cancels-25%-of-the-time maintenance, so this would be a luxury. Gary
PostPosted: Thu Jan 19, 2023 3:23 pm
I still have 'em in stock, but the Dodge A-vans and D/W-trucks use a different kind of switch than the passenger cars, so if this is for your A-100 in your avatar, I'm afraid I can't help. But if it's for a passenger car, send me a PM.
PostPosted: Thu Jan 22, 2026 10:35 pm
They're baa-aack! The good turn signal switches, I mean. Plenty of both kinds ('62-'63, and '64-'69) in stock in Michigan. Scroll up to the original post to see (finally) new/better pics.
PostPosted: Sun Jul 19, 2026 10:41 pm
I would love to have a new turn signal switch, but I am not sure it fits my A100 steering column? What is your verdict Dan???
PostPosted: Fri Jul 31, 2026 10:55 am
Oof. The A-, D-, W-series trucks use a different switch. Much harder to find. :-(
