It is currently Wed Oct 07, 2026 12:35 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Thu Sep 24, 2026 3:59 am
Car Model: 1984 Dodge W100 slant six
So im new to forum. I bought a 1984 W100 slat six, four on the flour, 11” clutch, low mount starter. I can’t find a clutch anywhere! Just a replacement, not a $6000 Ram racing clutch that probably wont work either. This thing has some goofy kind of flywheel that has the six pressure plate mount holes on some cast standoff spuds. Every flywheel Ive ever seen is FLAT! Nobody has a clutch for this setup. I got sent a clutch from ebay and the disc and throwout bearing are fine but the pressure plate must be V8. Wont fit in bellhousing. Can anyone help? Image
PostPosted: Thu Sep 24, 2026 9:41 am
Yes there are some posts on here about a really weird setup on those 11" clutches. What we did with ours was just buy a flat 10 1/2" small block V8 flywheel and then drill out the one hole that is offset for the slant 6 crank pattern. Then you can buy any stock 10 1/2" clutch assembly and your good. I will try and find the post for you later today. If I remember correctly the new flywheel for the 10 1/2" clutch was a 130 tooth ring gear and that was the same as the 11" one was. That was a little weird. Part numbers we used are in the next post.
PostPosted: Thu Sep 24, 2026 9:44 am
https://www.slantsix.org/forum/viewtopi ... el#p475063
