It is currently Wed May 06, 2026 11:34 am
PostPosted: Sun Sep 05, 2004 7:44 am
Can I bolt a 4 speed transmission to a 3 speed belhousing?
PostPosted: Sun Sep 05, 2004 8:55 pm
yes i did it 30yrs ago in a 64 cuda you have to weld the bellhousing to and a plate for the bolt patern
PostPosted: Sun Sep 05, 2004 8:57 pm
yes i did it 30yrs ago in a 64 cuda you have to weld the bellhousing to add a plate for the bolt patern change from 3-4 speed
 Post subject: Only with an adapter....
PostPosted: Sun Sep 05, 2004 11:13 pm
Only with an adapter or having the 3 speed housing re-machined. On many 70's mopars some 3 speed cars came with the 4 speed bellhousing as it is machined with both 3 and 4 speed patterns....
In a quick bolt up, you might not, but check to make sure you don't have an extra set of threaded bolt holes in your bellhousing....
