It is currently Tue Oct 06, 2026 10:41 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Sat Sep 26, 2026 9:20 am
Did you read the link I posted? Yes you can install a flat small block flywheel with 130 tooth. Ours was a high starter as well. Here is the picture of the flywheel.
PostPosted: Sat Sep 26, 2026 9:34 am
Car Model: 1984 Dodge W100 slant six
Cool. Thats the flywheel all right. So just get a 130 flat and clutch. Same bell housing? I’ll get the clutch and flywheel to have on hand. I did read back on your previous post. Thanks a lot!
PostPosted: Sat Sep 26, 2026 9:36 am
I’m guessing to fit the 11” they had to recess disc into flywheel.
PostPosted: Sat Sep 26, 2026 2:11 pm
Yes same bell housing. You just have to drill the one hole in the v8 flywheel to fit the slant 6 crank pattern.
PostPosted: Sat Sep 26, 2026 2:36 pm
Awesome! Thanks so much.
Users browsing this forum: Bing [Bot] and 17 guests
