It is currently Sat Nov 21, 2026 12:39 pm
PostPosted: Mon Oct 12, 2026 4:43 pm
This was on Facebook.
This gentleman raced a big ford back in the Modified Production Days.
"Robert Eliezer
Nice work. The issue with the pre-modern inline high performance six cylinder engines is always the same, especially with the “big block” 292 and 300s.
How do you feed a big block size cylinder volume with ports better suited to an early 265 Chevy V8 or Ford 260? The answer is always the same as well. You’ve got to keep the intake valve open as long as possible (duration) and as much as possible (lift) to allow the incoming fuel/air mixture to pack the cylinder as much as possible.
In our case with the 300 in 1975 it was an absurd Howard roller cam with 320 degrees of duration @ 0.020 lift (approx 285 @ “.050) and almost 0.0700 valve lift which was unheard of at the time even for the Pro Stock big blocks. It worked but at a cost. Valve spring technology was not up to the task and we broke at least one valve spring on every pass. And of course without the benefit of fluid harmonic balancers the 7,000 rpm operation and six cylinder 3rd harmonic vibrations would crack the forged cranks, both 292s and 300s, after 30-35 runs. It was just the cost of speed.
Later technology like the lump port heads for the 292s with 3 huge 2barrel carbs made by cut in half Holley Dominators allowed hp numbers over 600 while the 300s pretty much peaked around 500 with two ring pistons adding almost 30hp on our dyno and the second owner of our Maverick adding another 70hp with a billet crank featuring SBC size rod journals to further minimize parasitic friction losses. Our 2700# former H/MP car now runs routine 10.70s on the nostalgic circuit 53 years after brother Dick and I built it.
This cylinder head limitation is the same reason the Fords made quantum leaps in performance with the cut up and welded BOSS 302 cross flow hybrid heads and today with turbocharging.
Just thought a few of you inliners might enjoy a trip down memory lane. With my racing days long over my personal “special” ride for the last 43 years has been my 58 Chevy sedan with a tripower (3-1 barrels) 261 along with the usual headers, cam, posi, etc. Flawless operation for over 40,000 miles never touching a carb screw or having the distributor cap off the Mallory full centrifugal dual point. A bit of benign neglect there but it just works."
PostPosted: Tue Oct 13, 2026 8:46 am
Good styff Stan!
PostPosted: Tue Oct 13, 2026 9:41 am
Thanks Killa Zilla
We seem to be at a standstill right now.
PostPosted: Tue Oct 13, 2026 9:50 am
I have a couple cams from Mike that are +.600". I also know he experimented with more but abandoned it.
There were some who did use more. Maybe Junior knows. :shock:
PostPosted: Tue Oct 13, 2026 10:14 am
Tream Green Ran a skookum as frig cam
Check SSRN #28 for the oohey goohey detials.
PostPosted: Tue Oct 13, 2026 11:41 am
Tilley tried bigger cam lifts and they did not work well on the dyno. Long durations, yes, up to 270 or 275 @ 0.050".
PostPosted: Fri Oct 16, 2026 2:50 pm
Car Model: 1966 Dodge Dart
Thanks Killa Zilla
I think we're seeing more experimentation with turbos and electronics, though.
Matt Cramer
PostPosted: Fri Oct 16, 2026 3:32 pm
You are right about that!
PostPosted: Sat Oct 17, 2026 5:24 am
Not much to motivate some of us to build bigger, better, faster without our series to race in. I would like to build a lightened crank .104 over, offset valve head engine with 12.5 to 1 compression. But honestly what would I gain? Maybe a car that runs 12.40-.50 instead of 12.70-.80. I still might do it, but much more likely to do it if we were racing 4 -5 times a year.
PostPosted: Sat Oct 17, 2026 6:41 am
I will try and find what Cotton Perry told me a few years ago.
Computer crash, so I lost a lot of stuff.
It was similar to what the ford guys were doing.
PostPosted: Sat Oct 17, 2026 7:24 am
Cotton Perry
If memory serves me correctly he went through crankshafts like I go through ice cream! :D :D
PostPosted: Sat Oct 17, 2026 1:53 pm
I think Jim Cox told me they tried a .700" roller. They did a lot of different things.
I know when Mike retired I got to see some stuff they tried that didn't work.
The early 2000s when the race to the 10s and then 9s was an incredible time to be a Slant racer.
PostPosted: Sun Oct 18, 2026 6:53 am
Cotton Perry
I don't know about your ice cream addiction, but yes, cranks very often.
PostPosted: Mon Oct 19, 2026 1:14 pm
Pops is right again!
Racing Meril and Gary was exciting in the early '90's also.
Jr.
PostPosted: Mon Oct 19, 2026 5:31 pm
Make Slant Six Racing Great Again!
