It is currently Wed Oct 21, 2026 11:49 pm
PostPosted: Thu Sep 12, 2024 7:51 pm
Aye. Could probably even make it work on an earlier BBD, when the original lever was swaged rather than bolted onto the end of the choke shaft, though that would obvs take more work.
PostPosted: Thu Dec 26, 2024 10:28 am
Looks like all the various ways we've been adapting the chokes on 273-318 BBD carbs for use on a Slant-6 are obsolete, as the correct Slant-6 choke lever can be bought as an individual part for six bucks.
Cool! I just ordered one. I will compare it to a factory slant six BBD part when it gets here.
PostPosted: Thu Dec 26, 2024 10:46 am
I bought a couple or 3 of those from some carb shop seller out of Chicago -ish via eBay 3-4 years ago. So far Ive only used 1 but got the others while the gettin was good ...not much money and I figured that next time I need one I won't be able to, and I plan on there being more ,...
PostPosted: Sat Jul 12, 2025 6:11 am
Double Post
PostPosted: Sat Jul 12, 2025 1:34 pm
I forgot to update this. I received the part and it is a perfect copy of the original. Works great, too.
PostPosted: Fri Oct 16, 2026 6:47 am
This is a helpful thread. Anyone try this quick fix from Quadrajet Parts with the electronic choke conversion kit? Does it make a difference, or is it only a good fix for the factory choke set up?
PostPosted: Fri Oct 16, 2026 1:21 pm
The choke lever configuration needed for proper operation on a Slant-6 is the same whether you're using the crummy factory-type choke thermostat or the better-idea № 1232 electric choke kit.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 23 guests
