It is currently Mon Nov 23, 2026 11:00 am
Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3
PostPosted: Wed Oct 28, 2026 6:16 pm
We have had the most lovely stretch of ~12 Days of dry, balmy weather here in Western PA... Rare for any time of the year, but sublime in October.
Clear star and moonnlit skies in the morning and only going down to ~52° in the evening. AC/ Heat has not run in days!
Ava wanted to go see the mountain sunrise spot on Saturday.
We took the Duster.
After sunrise, we haeaded back down the mountain and got breakfast. I noticed the LF Wheel had something like -6-10° of camber. either something broke bent, or the Upper Control arm bar bolts slid around when I hit some of our famous Western PA potholes.
The alignment shop that I used to use closed up shop. so I will likely fix this one on my own.
Then it was home to pick up the '69 Dart and Michele for a picnic, photo shoot and a band show.
PostPosted: Thu Oct 29, 2026 5:51 am
What a lovely trip, Greg. Thanks for sharing that. Warmest wishes to you, Ava, and Michelle!
PostPosted: Thu Oct 29, 2026 6:40 am
Yep for sure.
The rest of the day happened too, but in a different car. I will post that with the '69 dart thread.
Pictures are now blocked here, so I'll get to sharing that sometime.
PostPosted: Sat Nov 07, 2026 5:27 pm
Found out after returning home on the 10/28/26 Sunrise trip that I hit a pothole or some other PA road surprise and cracked and bent the K frame on the duster. It was bound to happen after 47 years, salt and ~247,000 Miles.
I was able to make it home, then back to the garage to inspect the car.
I just tossed one of these F body K frames in the scrap because I thought it was too rusty.
Then the one on this car rusts and breaks too!
So There was an '80 Lebaron 2 door at my Dad's shop. Mom wanted to scrap it and I did not have the time / energy / motivation / resources to pull the K frame for myself while we were in possession of the car.
I should have pulled this part months ago while we owned the thing, but it was way easier at the Pittsburgh Mega Junkyard about ~10 miles outside of downtown Pittsburgh. I have never been there before. Mom has been selling ~30-40 Of the cars off of the lot to the yard over the last 5 years.
Fortunately the OLDMANTAN LeBaron with slant 6 was still there!
Brian D and I Jammed on this thing and got the frame out in 1 Hr and 38 min.
My home made Slant 6 Lifting Bracket came it super handy. They have portable cranes all around the yard for lifting big stuff for free!
It was clean and level too. Rare for these parts!
Here is Brian, happy to pitch in. I bet if I was working alone it would ahve taken 4 Hours to pull this part.
Forum Member rodJu, Justin lives only maybe ~4 miles away. He stopped in and said hi as well, and picked up a steering box and the Dash bezel from the Lebaron. (I did not get a picture of Justin, sorry)
This K Frame has a little rust, but I can clean it, wheel it all down, weld it and reinforce it and repair the small rust spots as needed before the install to my duster. I am sure this unforseen project will keep me busy to the new year.
PostPosted: Sat Nov 07, 2026 7:27 pm
Car Model: 67 Valiant, 73 Duster
A good time was had by all…but I was late to the party as Greg and Brian are very efficient and were wrapping up when I arrived. Removing a k-fame outside on a 45 year old car in under 2 hours gotta be a record. But having worked with Greg before, it’s not a surprise.
As Greg mentioned, I benefited from a steering box removed without turning a bolt.
PostPosted: Sun Nov 08, 2026 7:38 am
But it's gotta be weird having to pay someone else for parts of a car that used to be yours... When the parts would have been free... How much of what the junkyard paid your family for this car dis you have to give them back?
I gave away my last f body /6 k frame off a car I parted out years ago, to a guy who was gonna somehow cut it down and fit it into an oliver farm tractor along with a /6 he already had laying around. I don't know if he ever got anywhere with that or not.
PostPosted: Sun Nov 15, 2026 6:33 pm
Yes weird, but when you sell something, it is no longer yours. I am okay with this. We probably stuffed ~200 Tires in cars that we sent to that yard already!! They have been helping my family out immensely. 7 More A Bodies slated to be towed there tomorrow.
It was also so much easier to do this work at the yard. The car was 2' in the air and they had a free crane to use. The Spindles were already taken. It made a 4-5 hour job take 1 hr 38 min. My time is worth what I paid for the parts.
PostPosted: Sun Nov 15, 2026 6:40 pm
I degreased and hosed down the donor K Frame today and will be cleaning up the horrible factory welds.
It has some areas that need repaired, but I can do that, no problems with cutting and welding. there is enough good usable metal to work with.
Much of this frame is solid and usable.
Image[
I will be doing a bunch of metal work and welding / reinforcement soon.
PostPosted: Wed Nov 18, 2026 6:38 am
Making some progress on K frame prototype reinforcements:
After 3-4 Test fits in paper or cardboard, I will get them made in steel and fire up the welding gun!
Hopefully these will help to eliminate **some** flex. I will be fitting these on the car at some point to see if I can also add material toward the centerline of the car. I have had these upper control arm mounts crack/break on me before.
I also bought the tool to help move the upper control arm bar around to set the alignment.
PostPosted: Sat Nov 21, 2026 12:12 pm
I made some progress on this rather unexpected K Frame project:
A bunch of templates were measured and made. Next they will go into AutoCAD before the laser cutter in metal.
There was one area on my donor K that was total garbage. I cut out the rot, placed the opening in the template and traced away.
I am also making some additional reinforcement plates for this install. The Right Rear mounting area was not compromised, but I am going to plate it.
After Making the templates for the mounting areas, I cut away all the rotted garbage, welded up existing seams that I cut open, and peeped this area for new metal.
It's a bit hard to see what is going in int those pictures because i have an old cut up underside from a '64 Dart hood under there. it is showing plenty of surface rust on top of my work area.
I am also going to make templates / reinforcements for the "upright mounts". 3 Pieces of steel can be added and plated onto what is already existing there.
Off to do some mouse click'n' and drawing.
PostPosted: Sat Nov 21, 2026 5:17 pm
That's on the one that you pulled from the lebaron in your junkyard pix?
PostPosted: Sat Nov 21, 2026 6:01 pm
Yes. No better ones to be had around here.
PostPosted: Sun Nov 22, 2026 6:35 pm
All of the homework is done, many clicks, zooms, pans later the 6 cardboard paper templates are digitized and sent off to the laser cutter.
I will not get the parts until after thanksgiving, but that is okay, as I plan to seam weld and continue to reinforce the existing metal on the "new" donor K frame.
The 4 templates on the left side will be cut in 0.188" ( from the best I can detect / measure the upper arm supports were originally stamped in 7ga. steel. The 0.188" is a skosh thicker than that material . I measured the take off parts after media blasting at ~0.155" which is thinner than 7ga. but not quite 8ga.(yet).
The 2 larger plates on the right in my drawing will be made in 0.250" material.
All of this extra work should help to beef up the K frame. and reduce flex (hopefully).
