It is currently Sun Nov 29, 2026 8:19 pm
PostPosted: Tue Nov 24, 2026 12:35 pm
My car runs great. No problems as far as performance goes. It generally runs in the 12.80-12.90 range with a best of 12.70@104.7 mph. My question is for a future engine refresh, which I have no Idea when I will do. It is hard to pull apart a perfectly good running engine just for fun. But when I do I want to have all the parts on the shelf to do everything.
My question is regarding a camshaft upgrade. Current camshaft is a Oregon regrind with the following specs:
Intake----.571 lift---267 @.050 duration
Exhaust--.550 lift---262 @.050 duration
It has 106 degree lobe separation, Intake C/L 102 Degree, installed at 99 degrees, 52 1/2 deg. overlap @.050
With valve lash at .024 it only has @160# cranking compression. Tried the valves up to .032 and it really didn't make much difference. This engine is a 11.5 to 1 static comp. ratio.
It appears that it is bleeding off a lot of compression?? So if I were to use the same grind cam and increased the LSA would that increase the cranking compression? Or is there something else you would try if it was yours to squeeze out a couple more horsepower? Again this is just a "what if" type thing now. Give me your thoughts. Thanks
I do have a new set of Weisco 3.504" pistons (currently 3.484") and I always wanted to cut about 10# of counterweights off of a crankshaft and try that. Just dreaming out loud :D :D
PostPosted: Wed Nov 25, 2026 7:44 am
Sounds like a lawn mower cam to me
It least that is what my "Fans" call my cam
PostPosted: Wed Nov 25, 2026 4:56 pm
That's true! But at least we are still racin Stan! :mrgreen:
PostPosted: Wed Nov 25, 2026 6:10 pm
It's over .550" lift. It's good. :mrgreen:
PostPosted: Thu Nov 26, 2026 7:12 am
Where is SlantZilla, and what have you done with his Body??????????????
PostPosted: Thu Nov 26, 2026 7:36 am
Stan I think he is getting soft in his old age! :D :D There is always the possibility that when he typed .550 he meant .750 !!
PostPosted: Thu Nov 26, 2026 7:43 am
:mrgreen:
The rule is less then .550" lift belongs in a lawnmower.
PostPosted: Thu Nov 26, 2026 11:39 am
If I were to use the same grind cam and increased the LSA would that increase the cranking compression?
I have been doing more research and found that this statement is almost surely false. Overlap has very little to do with cranking compression. And it is almost all related to the Intake valve closing point. So for 2 equal engines, one with a LSA of 112 and one with 106, the one with 106 LSA will have more compression. Just the opposite of my thinking.
PostPosted: Fri Nov 27, 2026 4:37 am
Hi Rick,
Happy Thanksgiving and sorry I'm late to this thread. Contemplating some things...
Yes, it is the intake valve closing point that matters. I am surprised you are only seeing 160# cranking with this cam and 11.5:1 static CR. If you want to go faster, I would probably mill the head for 12:1 or a bit more. I assume you have tried more than one compression tester to make sure your gauge is not off? Can you run comfortably on pump premium gas without dieseling on shutoff? You'd have to run it out of race gas or pump it out of the tank, then refill with 93 for this test. You might also try measuring intake closing point directly to see what you get?
I am also completely stumped as to why Greg's car slowed down so much with cam specs that should have worked based on all my research. There is always a limit to knowledge and experience and theories...
Hmmmmm.
PostPosted: Fri Nov 27, 2026 6:21 am
Lou, I am pretty sure that I used 2 different gauges, but it was over a year ago. Intake closing point on this cam is 56 ATDC
PostPosted: Fri Nov 27, 2026 7:37 am
Ok, since I am getting old and don't remember what I had for breakfast let alone a year ago, I went back and checked what I did. I actually did use 2 different compression testers and they were the same. Leak down test was good also. What I didn't remember is that when I opened the valve lash to 32 it did raise the compression to @ 172 which was a good bit higher than before. But what it didn't do was change the actual on track performance that I could tell. It ran just about the same as always.
All In all I am guessing this is a pretty good cam for my car. With only 170# cranking compression, I probably could get by on premium pump gas like Lou said. And even if I needed to pull a couple of degrees of timing out that would be no biggie. If I really wanted to go faster I would probably need to go to my +.104 oversize pistons, which would reduce shrouding and help flow. And then bump the compression a point or so. So maybe I will just leave well enough alone when I freshen the engine.
PostPosted: Sat Nov 28, 2026 12:11 pm
Ok, cool. I thought I remembered it picked up some cranking compression psi when you loosened the valves. I am also happy to see that it ran just as well with the wider lash. That should not affect top end performance hardly at all (if at all) but will make idle and low speed better. Honestly, that cam should be about perfect for 11.5:1, and even should allow pump premium running. Yep, likely a bit less advance would be good for that. My guess is that 26-28 deg full advance at WOT will be about right, but YMMV.
Slant on,
