It is currently Sat May 02, 2026 7:15 pm
 Post subject: 8 3/4 to 8 1/4 swap
PostPosted: Sun Sep 12, 2004 8:37 am
Want to remove a 8 3/4 rear end and install a 8 1/4 rear end in a '68 Dart so I can run big bolt pattern wheels.
-Will the old drive shaft fit? Or will I need longer or shorter?
-Will the good brake assemblies (backing plates and all) swap to the 8 1/4?
-What else might I need to know?
Thanks,
Bobby
 Post subject: Err...
PostPosted: Sun Sep 12, 2004 10:06 am
Why not just swap in a set of BBP axle shafts from Moser or Strange and keep the 'better' 8 3/4"?
PostPosted: Sun Sep 12, 2004 2:28 pm
You'll need a longer shaft. I'm pretty sure that brakes will swap over but can't be positive.
I'm with DI on this one, for $200-300 you can get moser axles in any bolt pattern you want. Check out www.moserengineering.com
Or better yet they can redrill your current axle for $50-70 if there is enough room. They can redo drums as well.
PostPosted: Sun Sep 12, 2004 4:30 pm
you would need a longer shaft by 0.65".
PostPosted: Sun Sep 12, 2004 7:44 pm
.065" is only about 5/8", if you have a slip yoke, I wouldn't think that small amount would hurt a thing, certainly not worth a trip to the driveshaft shop for.
