It is currently Sat May 02, 2026 10:27 pm
 Post subject: $100 rear end
PostPosted: Sun Jul 25, 2004 11:40 pm
Here's my ford explorer 8.8" rear end with 3.73 ratio and posi I got for $89 at the local u-pull-it. I narrowed it 3'' and put on some Mopar spring pearches ($12.99 at Jegs) It's ready to install.
<img src="http://homepage.mac.com/howtoplaydead/.Pictures/mustangmopar_rear.jpg">
Franklin
'61 Valiant
PostPosted: Mon Jul 26, 2004 1:48 pm
Looks good, but didn't the exploders come with rear disk brakes?
PostPosted: Mon Jul 26, 2004 4:38 pm
'94 and later came with disc brakes, earlier models had 10'' drums. All have 5 on 4 1/2" bolt pattern.
Franklin
'61 Valiant
PostPosted: Fri Jul 30, 2004 8:53 am
What does that sucker weigh? I'd really be interested before you install it...
PostPosted: Wed Aug 11, 2004 4:30 pm
It weighs about 190 lbs with the drums on a bathroom scale.
Franklin
'61 Valiant
PostPosted: Wed Aug 11, 2004 6:35 pm
Thanks much for the weight - about 10lbs lighter than a comparable 8.75" mopar axle.
PostPosted: Thu Aug 12, 2004 2:15 pm
Yes, it's a little lighter than a 8 3/4 or 9" and supposedly less parisidic drag yet nearly as strong.
I was originally going with an A body 8 3/4" but after getting all the parts together and realizing I'd spent $700 for a housing, sure-grip and decent gears, I sold it.
The junk yards are full of explorer 8.8s with posi and 3.55 or 3.73 ratio. If you want 4.10 or 4.56 ring and pinion, they're cheap on e-bay.
It's real easy to narrow, you don't have to re-spline any axles.
Franklin
'61 Valiant
 Post subject: narrowing proceedure
PostPosted: Thu Aug 12, 2004 9:13 pm
How is the explorer rear narrowed without resplining axles?
PostPosted: Sun Aug 15, 2004 3:44 am
nice question ? how to shorten the rear end ? i,m also in this trouble got a 8" 54 "" and need 52" long . how to shorten a rearend ?
btw . i only have acces to euro cars , not easy for me to go to a yunk yard and pick a 8 ore 8,8 axle ! did took me 1 year to get a 8 axle , and it is to wide !!!!!!!!!!!!!!!
http://member.chello.nl/h.omvlee
PostPosted: Sun Aug 15, 2004 3:55 am
btw :http://members.chello.nl/h.omvlee/
i,m always looking into this site too , nice forum ! good tips and how to .
 Post subject: Narrowed How far?
PostPosted: Sun Sep 12, 2004 3:06 pm
Hey,
When you say that you narrowed the FMC 8.8 3" do you mean 3" total or 3" on each side? Also, what would prevent you from using a disc brake version of the same rear? Ideas?
JRC
When in doubt, empty the magazine.
'72 Dart Swinger /6 - My Yard Dart!
'01 Ranger P/U 4x4 X-cab
We buy and sell MOPARTS & Ford Parts!!!
http://www.usironauto.com
PostPosted: Sun Sep 12, 2004 6:52 pm
The explorer 8.8 is 59 1/2", but the center section is offset about 3" to the right. So I cut 3" off the left tube and used another left axle and now its aprox. 56 1/2" wide.
You could use the disc brake model with no problem except adapting the parking brake cable, which looks pretty easy.
Franklin
'61 Valiant
PostPosted: Sun Sep 12, 2004 6:56 pm
That should read, "I used another right side axle".
Franklin
'61 Valiant
 Post subject: Offset
PostPosted: Sun Sep 12, 2004 7:16 pm
Ah,
I am very curious how this entire project turn out. This rear end swap is of particular interest to me since I am also into Fords. I've owned 2 explorerers and modified one fairly extensively, the rear end never broke, even when being used for makeshift rock crawling. Can't say as much about the TTB Front suspension though :(
you should really submit this entire thing to the powers that be here on sl6 and get it made into an article! :)
PostPosted: Sun Sep 12, 2004 7:47 pm
Car Model: '23 T-bucket
Hmmmmmm.....I wonder if a spool is available for the Ford 8.8? I'm giving some thought to a rear-engine , slant-powered dragster, but really don't want to use an 8.25" rear.
Roger
