It is currently Tue May 19, 2026 10:11 am
 Post subject: spring shackles
PostPosted: Wed Sep 15, 2004 4:29 pm
When Alex and I changed the rear springs in the Valiant we added poly bushings. When the springs were removed we broke the shackle bolts. The original bolts were 3/8 and our new bushings were 7/16. We made up new shackles using 7/16 bolts but are not satisfied with the result. Do we order B-body shackles to get the larger size? Where can you get them?
 Post subject: Rare Parts
PostPosted: Wed Sep 15, 2004 7:34 pm
The www.rareparts.com place in Stockton,CA is where I just bought a set
for my Valiant - The PN 35110 fits 63-70 and contains rubber bushings,
bolts, and the stamped sides. The bolts are just a shade under 1/2" dia
where they go through the bushings then step down to just under
7/16" dia where the stamped shackle sides sit on the bolt.
The shackle kits cost $23 each. Their phone is 209 948 6005
PostPosted: Wed Sep 15, 2004 10:45 pm
http://www.springsnthings.com/ has all the bolts, bushings and shackles you want.
PostPosted: Thu Sep 16, 2004 7:01 am
The poly bushings I've used are about 1/2" ID, so I just used some flat bar stock and 1/2" bolts for the shackles. Weld the bolt heads to the stock to eliminate non-square flexing of the shackle.
PostPosted: Thu Sep 16, 2004 7:07 am
I think we are headed towards a local solution. We kinda sorta have Lous solution now.(had to get the car together). I will have the car for a few days while Alex does a delivery to Wichita in the Roadmaster. Methinks a serious couple of hours with bolts/hardened washers and a welder are in order. The stock shackles look pretty lame....3/8 bolts
Users browsing this forum: Amazon [Bot], brummett and 3 guests
