It is currently Mon Apr 27, 2026 5:17 am
PostPosted: Tue Sep 21, 2004 8:32 pm
Hi all,
Can anybody tell me what the correct description of the bolts that attach the rear spring hanger to the body? They are kinda 3/8" coarse, but they expand out, and a regular 3/8" bolt is loose in there. I broke one off, and I need to get a new one. Does D/C still carry them? I would look in the parts DB, but it appears to be down again.
PostPosted: Wed Sep 22, 2004 9:07 am
I just got back from a dodge dealership, and yes, the bolts are somehow special, and of course, they are discontinued. Any thoughts on where I should look? Does somebody have two sitting around the garage that they could part with?
PostPosted: Wed Sep 22, 2004 9:42 am
If you only broke one off, the other 3 should locate the perch just fine. I say just use a standard 3/8" grade 8 bolt.
PostPosted: Wed Sep 22, 2004 9:51 am
They are hub bolts, basically smaller versions of lug bolts. They have splines under the head to keep them from spinning in the hanger. A regular bolt will work okay but if you really, really need an original you can get it from AMK Products. They cost $1 each.
PostPosted: Wed Sep 22, 2004 2:58 pm
Hi Andy and Lou,
I'll call AMK. They might be able to help. The bolts that I am looking for are from the rear hanger, not the front (rear) spring hanger. The nut is welded on to the subframe, and I believe, that I cannot get in behind it to put on a nut that actually fits. This is why I am actually looking for the orginal bolts, and not just grade 8. I will check to see if I can get behind it when I get home tonight.
The bolt in question is some sort of self tapping bolt, and it does expand in diameter slightly to something slightly larger than 3/8.
Thanks, though, and maybe AMK could help.
Update: I just checked AMK's website. $30 minimum order! Arghh. Any other suggestions? This was really close, and I really appreciate your collective expertise.
Update II: It is looks possible, but difficult to get in behind the bolt to put a better nut back t here. Arghh!
PostPosted: Thu Sep 23, 2004 7:17 am
I was looking at Tom Condran's book, and he is referring to these at 7/16". Since they are tapered, this might be the major part of the bolt.
Hmm... I'll have to check this out.
PostPosted: Thu Sep 23, 2004 9:21 am
ah, rear hanger on the leaf springs. i thought front hanger on the rear springs.
i haven't looked at those in awhile so i suppose i'm not much help. they vary by year and model to some extent.
Users browsing this forum: Rick Covalt and 2 guests
