It is currently Thu May 14, 2026 7:58 am
PostPosted: Wed Oct 06, 2004 7:58 pm
I've tried everyone I know without success, so I'm asking you guys in hope you can help. My 1961 Chrysler 300-G has the 3 speed torqueflite, which isn't as strong or durable as an aluminum T.F. such as in 1962 and later cars. Can anyone tell me who makes an adapter plate and brackets necessary to match the later model aluminum T.F. to my crank shaft, which has a smaller pilot hole. I think someone makes an adapter due to the longer space allowed by the later tranny. Your help will be greatly appreciated. Thanks.
Restored '62 Signet, 229 4bl, Offy intake, auto, Dual Dutra exhausts, shaved head and block, high stall converter, 1.6 roller rockers, etc.
PostPosted: Thu Oct 07, 2004 6:56 am
Any trans up to '67 will have the right torque converter to bolt up to your small crankshaft hole (all Slants had this small hole up until 1967). The '66 and '67 trannys were the first non-cable-operated ones, and used a standard slip yoke instead of the older ball/trunion driveshaft. '62-65 trannys will also work, and are cable operated and have the 4-bolt flange for the driveshaft.
 Post subject: aluminum torqueflite
PostPosted: Mon Oct 11, 2004 8:14 pm
Thanks, guys. Lou, will I need an adapter plate because of different shaft length at the front end of the transmission? Of course, the '62 was the last year with the emergency brake at the rear of the tranny, except for some RV trannies. How much work is it to go to the cable type emergency brake leading to the rear brakes? Can I scavenge this from an old C body for my '61 300G? Thanks.
PostPosted: Tue Oct 12, 2004 7:38 am
No adapter as long as you use the torque conv that goes with the trans and fits the crank hub hole. Don't know about park brake stuff.
