It is currently Sat May 09, 2026 6:29 pm
PostPosted: Tue Oct 12, 2004 2:23 pm
switching from p/s to manual in my 63 valiant. other than a manual column and box, is there anything thing else i need to change?? how bout pittman arm will it bolt to manual box?? thnx,,,,,,,,,,,,,steve
PostPosted: Tue Oct 12, 2004 9:00 pm
The suspension catalog for RareParts only lists one pitman arm for 63-66.
I interpret that to mean the power steering and manual steering arms are
the same one.
Check out the belt configuration for the power steering pump - you
might need idler pulleys or some brackets to change the belt
geometry to get rid of the pump if it shares the belt with another
accessory.
 Post subject: swap
PostPosted: Thu Oct 14, 2004 1:10 pm
relic-lover, thnx for the info on the pitman arm, good news for sure. as far as the pulleys, there are 2 crank pulley grooves. so eliminating p/s just leaves an empty groove. i would like to only have a single groove pulley though.....steve
