It is currently Fri May 22, 2026 2:09 pm
 Post subject: Gettin axles out.....
PostPosted: Tue Oct 12, 2004 4:16 pm
Can someone outline the procedure to get the axles out of a 67' 7 1/4 suregrip rear diff. Thanks.
"that's a nice car....are you gonna fix it up some day?"
 Post subject: If it's the same
PostPosted: Thu Oct 14, 2004 12:28 pm
I'll be short because I can't promise it's the same as a later 7 1/4, but here is how it works (72 and up is all i've ever looked at)
Block the front wheels so car can be safely raised in neutral.
Take off the wheel and brake drum.
Remove 4 (or 5) nuts which retain axle bearing against brake backing plate. There should be a hole in the axle flange that permits access to the nuts.
Then Pull really hard or pry on axle flang till axle and bearing pops out.
If you're really in a hurry and don't trust me, pull the cover and check for "C" clips holding the axles in, I don't think they made 7 1/4 with "c" clips though.
1980 Aspen 225 super six
 Post subject: Free 7 1/4 sure grip
PostPosted: Thu Oct 14, 2004 12:29 pm
Or, offer a free 7 1/4 sure grip for the first guy who comes and removes the axles. :wink:
Your head will spin it'll happen so fast. :lol:
PostPosted: Mon Oct 18, 2004 8:33 am
If the bearing is stuck in the housing, just put the wheel back on and give it a whack on the inside with a big hammer. The bearing will pop right out of the housing. :shock:
PostPosted: Mon Oct 18, 2004 10:22 am
Gotta love the BFH... :roll:
 Post subject: Bfh
PostPosted: Mon Oct 18, 2004 6:53 pm
:D do you use a BIG FORD HAMMER, or a BIG FARMER'S HAMMER?
PostPosted: Tue Nov 16, 2004 1:14 pm
Thanks for the replys. Axels are out now. Got the shop to press off the old bearings/collar. New ones going on this week, new seals, rebuild the brakes then on to the next project. Thanks.
