It is currently Thu Jun 18, 2026 2:26 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Tue Oct 26, 2004 7:19 am
No problem. When I get it all correctly set I will be happy to do that. 8)
PostPosted: Wed Oct 27, 2004 7:30 pm
Okay, I think I got it adjusted right:
Flapper closed so the exhaust heats the carb:
With the flapper open so exhaust gasses go straight out the pipe:
Let me know if that isn't right.
PostPosted: Wed Oct 27, 2004 10:30 pm
That's it, good adjustment job.
Clean it up and bolt it on!
PostPosted: Wed Oct 27, 2004 11:32 pm
Will do! But first I have to cut the front leg off and weld it up.... :wink:
PostPosted: Thu Oct 28, 2004 1:49 pm
Eric
If youve dumped the flapper, your intake will be constantly blasted with hot exhaust, which will actually worsen hot start probs. The /6 works differently than the V8s
KG
PostPosted: Thu Oct 28, 2004 3:52 pm
Not so, in fact the exact opposite happens. Little if any exhaust gas reaches the bottom of the intake manifold.
