It is currently Tue May 05, 2026 2:12 pm
 Post subject: Stripped #6 plug threads
PostPosted: Mon Nov 08, 2004 3:30 am
Anything I can do without removing the head? It's the head, not the plug... I've got the heli-coil kit, air compressor, shop vac, etc for any tried and true methods...
Thanks for any help - Mike M
STEALTH DART
disappears at dusk!
PostPosted: Mon Nov 08, 2004 8:18 am
It's "meatball surgery" time. :evil:
Bring the piston near the top on that cylinder. (leave yourself some tap tip clearance)
Put a lot of grease on the tap, this helps hold the "chips". Back-out the tap and clean / re-grease it often.
Install the Heli-coil as directed. Try to "stake" the top with a punch so it will not "unscrew" when you remove that plug later.
Use some anti-seize on that plug thread and don't over tighten it.
PostPosted: Mon Nov 08, 2004 8:42 am
thank you Doc, I'm on it!
STEALTH DART
disappears at dusk!
 Post subject: And
PostPosted: Mon Nov 08, 2004 9:43 am
Before you install the plug, crank the engine over a few times, and the compression may help blow out any metal that fell in.
1980 Aspen 225 super six
PostPosted: Mon Nov 08, 2004 10:12 am
Or a skinny magnet on a stick, often sold in parts stores to help pick up dropped nuts and bolts in tight spaces. Run it carefully down the plug hole and pull it back gently a few times to pick up any flakes left.
PostPosted: Mon Nov 08, 2004 11:33 am
more good advice, thank-you
STEALTH DART
disappears at dusk!
