It is currently Wed Jul 15, 2026 9:41 pm
 Post subject: dsf
PostPosted: Tue Nov 09, 2004 6:02 pm
I wasw just thinkin about headers! is it possible to keep the single exhuast. and if you are doin dual, how does it work out. im confused
places?prices?
PostPosted: Tue Nov 09, 2004 6:28 pm
I have clifford split headers with a (looks like) cliffored Y-pipe going down to a single 2.5" pipe. That goes to a 2.25" in and out cherrybomb turbo muffler and 2.25" pipe out the back. The Headers and Y-pipe I bought used at Carlisle last year for $75, the muffler was $20 at pep boys, and the pipes were made at Monroe muffler brake for $90= $185. one option.
PostPosted: Tue Nov 09, 2004 8:53 pm
Or use "Dutra Duals"...
These are cast iron dual exhaust manifolds, they are "Better then Headers". :)
http://www.dutra.org/doug/doug-sl6-exha ... -duals.htm
 Post subject: Dutra Duals Installation
PostPosted: Wed Nov 10, 2004 6:52 am
This is what Dutra Duals look like installed on my car.
Frank
PostPosted: Wed Nov 10, 2004 9:20 am
If you are after torque the single pipe is a good bet. I use headers , 2 1/4" primary pipes , Summit "Y" and 3" single sewer pipe on my "fleet" 5.7l s . My slant plans are similar but would utilize smaller pipe sizes. Given the displacement a slant would likely make most torque with 1/34 primaries and a 2 1/2 single. Primary length varies peak torque RPM.
In my experience the primary pipe diameter and length are far more important than tail pipe size/length for torque production and band width.
Chev 250s used to have a dual setup option (1980~) The pipe sizes were 1 1/2 primary 28 1/2" long leading to a 2 1/4 intermediate and a 2" tailpipe. a good model for a stock super 6.
A single pipe eliminates the "drone" often associated with duals and headers.
Any good muffler shop should be able to understand and fabricate this. Shop around.
