It is currently Wed Jul 15, 2026 3:02 am
 Post subject: manifold gasket?
PostPosted: Tue Nov 09, 2004 12:08 pm
I have ad my manifolds off twice now to replace the manifold gasket. right now i have the clifford duals and the stock intake on the motor. the last two gaskets were felpro. which gasket can i use to keep this from happening again? i think there are least four cylinders leaking right now. and the collector gaskets are pretty much gone too, so i will have to replace those as well. thanks for the sugestions.
zedpapa
soon to have 5 gears!!!
PostPosted: Tue Nov 09, 2004 9:21 pm
Both Clifford and the Cox boys have a thicker material I/E gasket for the SL6
Also check the header flange for flatness, it may be bent / bowed to the point were nothing will seal.
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
