It is currently Sat Jul 18, 2026 11:12 am
PostPosted: Sat Nov 06, 2004 6:43 pm
I recently rebuilt my /6 in a 70 Valiant. I replaced the points with EI and put a Carter BBD from a 318 on it. I'm having some problems with rough idling and it seems a bit sluggish from a dead stop when I nail it. I have the timing set at 8 BTDC and have replaced the vacuum pod on the distributor. The car is also eating my lunch in gas. The plugs are showing signs that it's running rich also. If I nail it and then let off quickly, it acts like it wants to die but then picks back up. Would a vacuum leak around the throttle shaft cause these problems? Is the 318 BBD too much for it to handle? I have the original BBD from the SUper 6 setup that I have yet to rebuild. What about replacing the coil with something hotter? It just has a stock coil on it now but I have not checked the primary and secondary resistance values yet.
70 Valiant Super Six
PostPosted: Sat Nov 06, 2004 7:14 pm
sounds like the float has submarined
those things like to do that
could be a float level thing
remember you changed the angle the carb sits at
if it was close to to high then it would be
PostPosted: Sat Nov 06, 2004 10:03 pm
What is your total timing at cruise? Do you have your vacuum advance hooked up?
PostPosted: Sun Nov 07, 2004 2:44 am
Does the timing mark move as you rev up the engine?
Have you checked your valve adjustment recently?
What happens when you plug the PCV valve?
PostPosted: Sun Nov 07, 2004 4:53 pm
After replacing the vacuum pod, I hooked up my vacuum pump and noticed a that the timing mark did advance as I increased vacuum. It acts a little better from a dead stop now so I am assuming that it is now advancing properly. However, I have not checked my total advance at cruise. I have not adjusted the valves lately, so I'll try doing the running adjustment this week. Is there anything special I need to know before doing a running adjustment? I'll also check the PCV valve but I have also recently replaced it. What should it do when it is plugged?
What about using a hotter coil? Will that help my mileage? Which one should I use?
PostPosted: Sun Nov 07, 2004 11:14 pm
If you are going to use a 3/8 socket to adjust the valves, I would tape it to the extention. Those valves going up and down can knock it off and you don't want it falling down inside the motor. :shock:
 Post subject: Now What?
PostPosted: Wed Nov 10, 2004 5:56 pm
I'm obviously doing something wrong or I've got a problem I just can't find. I adjusted the valves with the engine running and was able to quiet down some of the clatter. That did not help my idle problem. I plugged the PCV valve and the RPM increased for a moment and then settled back down. It acts like a vacuum leak but I can't find it either. Any more ideas??? I've got another carb I'm going to put on it to see if it makes a difference. :cry:
PostPosted: Thu Nov 11, 2004 9:00 am
Check distributor cap contacts. If they are dirty it helps a lot if you clean them.
Sorry, my english is not very good
PostPosted: Fri Nov 12, 2004 9:06 am
One test is to cover the carb's throat during rough idle to see if the idle condition improves. (slowly close the carb flap is the way I do the test, you may have to back-off / disconnect the fast idle screw/cam)
If you can get the idle to improve by choking down the idle air flow, you have a lean idle condition caused by a vacuum leak or a clogged / lean idle circuit in the carb.
Have you done a compression test, are all cylinders even on compression?
