It is currently Mon Nov 30, 2026 7:30 am
PostPosted: Thu Nov 11, 2004 4:39 pm
Does anyone know what the average mpg is for a standard 225 1bbl slant 6?
So far ive calculated the gas mileage 4 times at various points in a 6 month range. So far they have been 11.5, 11.8, 11.1, 12.2mpg. Is there something that may be wrong with my engine? Im assuming I should at least be getting 15mpg with a 225ci. My engine has 92,000 miles on it with no performance parts. Ive already changed the carb and it didnt do a thing to my mileage.
The engine runs like a dream. Starts up every time and never quits on me. When it does quit it only costs $30 to repar. But I dont know how long I can go on driving this car if im only going to be getting around 11 mpg.
Any suggestions? Thanks
PostPosted: Thu Nov 11, 2004 4:53 pm
What car is this in? What about transmission and rear gear ratio?
There could be a boatload of reasons... vaccum leaks, burning oil... (check oil level periodically), running rich...
PostPosted: Thu Nov 11, 2004 5:53 pm
Need a little more basic info on the car. I would check the vacuum advance first, being as it starts and runs good.
PostPosted: Thu Nov 11, 2004 8:44 pm
Do you have the Holley 1920, the Holley 1945 or the Carter BBS 1bbl? What year and model is the car? What year is the engine? Automatic or manual transmission? Need more info.
PostPosted: Thu Nov 11, 2004 10:38 pm
Its a 71 Duster with an automatic tranny. Im not sure on anything else right now. I could go check the type of carb tomorrow during the day but I have no idea on how to tell exactly what type of transmission and rear end is in it.
Also could you please tell me what the vacuum advance is? Sorry im a bit illiterate when it comes to cars.
It probably burns about a quart to a quart and a half in between each oil change.
One thing that it does do (not sure if it affects the mileage), is it shoots out a lot of black carbon out of the tailpipe when I start it up. If I havent ran it for a day and I start it up, it shoots out quite a bit of black liquid.
 Post subject: Perhaps
PostPosted: Fri Nov 12, 2004 6:29 am
Be sure to replace your PCV (positive crankcase ventalation) valve. Mine was clogged and I've seen a 1-2 mpg improvement since fixing it. These are a common $3 item at the parts store. That's what fixed the black crud comming out my tailpipe.
It's a plastic elbow that fits into the valve cover and has a hose that goes to the carb.
If you haven't done a tune up in a while, new spark plug wires, spark plugs, distributor cap, rotor, and fresh points. You also should learn to do a valve adjustment. (do a search, it's been explained many times)
Athough we are always glad to help/answer questions, you will find a repair manual a valuable tool. They are usually easy to find on ebay or can be ordered through most parts stores. The pictures and procedures are very good for basic understanding, and then you can ask any questions you still have on this forum.
1980 Aspen 225 super six
PostPosted: Fri Nov 12, 2004 8:37 am
We all know that the SL6 is a strong engine and seeing that your car only have 92K on it, my guess is that the basic engine is in good shape.
So the poor mileage is most likely related to tune-up issues.
As already suggested, do a complete tune-up including a valve adjustment.
Note that giving the engine lots of spark advance, quickly, helps performance and gas milage so that should be a focus of your tune-up efforts. Read all the "distributor recurving" message for more information.
Testing / adjusting the vacuum advance "pod" is a great place to start looking for that lost MPG. The vacuum advance is the "silver can" screwed to the side of the distributor, it has a hose going up to the carb.
If you disconnect the hose from the carb and suck on it, it should hold vacuum and the rpms should increase as you do this test.
The next stop on your MPG search will be the carb.
Sad to say that your discription points to a possible rebuild carb that may have been set-up rich. Testing / rejetting the carb. should be done as a "last step", once the tune-up / valve adjustment is done.
 Post subject: poor mileage
PostPosted: Fri Nov 19, 2004 1:07 pm
does your car take excessive throttle to maintain speed? if you are pushing the gas pedal more than 1/4 way down to maintain speeds above 40 mph, it could be that the stator inside the torque converter is seized. i had the same problem getting almost the same mileage in my 70 dart with the same combination. found out after i did the 4 speed swap what it was. funny thing is the factory manual tells you how to check for it.
zedpapa
soon to have 5 gears!!!
 Post subject: 2c worth
PostPosted: Fri Nov 19, 2004 3:40 pm
I'd definitely think something was wrong if I got 12 MPG!
I have a 72 Dart Swinger with a 1920 holley. I get ~20 MPG with it mixed driving, and it isn't in THAT great of tune at the moment. My car has a 904 tranny and a 8.25" with 2.45 gears at the moment. I have another 8.25 with 3.21 gears and a suregrip that are scheduled to go in soon when the engine goes from (Gasp!) a /6 to a 408 (360+4" crank = Mopar happiness). I KNOW I'll be getting about 12-14 MPG with THAT motor, but again... 12 in that car seems WAY low...
When in doubt, empty the magazine.
'72 Dart Swinger /6 - My Yard Dart!
'01 Ranger P/U 4x4 X-cab
We buy and sell MOPARTS & Ford Parts!!!
http://www.usironauto.com
PostPosted: Sun Nov 21, 2004 8:47 pm
A couple of other things not related to the engine might be low tire pressure, and bad front-end alignment.
Not sure though if those things would be enough to put your mileage down that low.
I have a 63 Dart on the first motor with 136,000 miles, and a bad cam (one lobe is half worn down because the previous owner never changed the oil). It now burns a quart about every 200 miles.
AND, it gets between 17 and 18 miles per gallon.
PostPosted: Wed Nov 24, 2004 2:41 pm
Thanks for the help guys.
It does take a lot of gas to go. Is a slant 6 supposed to be really slow with a 1bbl? Ive raced quite a few people and the only car ive ever beat was a 4cyl 94 Saturn. The car is beyond slow off the line and I have trouble getting up to speed when im getting on the freeway. I have to floor it for quite some time to get up to 60.
I know the tire pressures are good but im not sure about the alignment. I'll have to get that checked out.
I'll try to mess with some of the things you guys have said but im not that great with cars. So I guess I'll see how far I can get.
PostPosted: Wed Nov 24, 2004 2:52 pm
You're not including races in your mileage figures, are you? If so, keeping your foot out of it will improve mileage considerably.
My '64 225/904 1 bbl BBS gets 17-18 around town with no effort in normal driving, and over 21 at 70mph on the highway. It blends in as far as acceleration and keeps up with traffic quite nicely.
PostPosted: Thu Nov 25, 2004 10:08 am
Wow - it should not be that slow. I'm not an expert, but my guess is that your spark advance is wrong, and your dwell is off. To check this, you will need a "timing light" and a "tach/dwell."
You can get these tools pretty cheap as a kit - I just checked and someone is selling some used ones on ebay for 10 bucks http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=43989
You'll need the shop manual for the car, as well (it will show you how to check these things) - it should be available either from Chilton, or as a reprint. Do a google search for it.
Does your car seem to slip between gears, or does the engine rev up a lot as you accelerate? I agree also that you may have transmission problems.
If anything, your car should have really good "off-the-line."
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Sun Nov 28, 2004 10:18 pm
The mileage checks were done without racing. I dont really race it much at all. Maybe once every 6 months.
As far as the tranny goes, it seems ok to me. It doesnt slip at all and the revving seems quite normal. Its just slow to get to the point.
I just got an auction for a manual and now ive put a bid on that light. When I get these in, I should have enough resources to at least get started on addressing the problem. Thanks for the help guys.
PostPosted: Wed Dec 01, 2004 12:30 am
My 70 Valiant was slow off the line and took awhile to get up to speed. Doc already mentioned the vacuum pod and that's where my trouble was. I had a blown diaphragm. As Doc said, disconnect the vacuum hose that leads to the pod on the distributor and see if it will hold vacuum by sucking on it. At least that will determine if the diaphragm is good. After replacing mine, it made a huge difference.
70 Valiant Super Six
Users browsing this forum: Ahrefs [Bot] and 1 guest
