It is currently Mon Nov 30, 2026 3:15 pm
 Post subject: intake manifold vacuum
PostPosted: Mon Nov 22, 2004 8:14 am
I just recently purchased a 1965 valiant signet, unfortunately some or most of the vacuum hoses are missing or what i guessed to be in the wrong location, my main concern is the distributor was connected to a vacuum coming out of the intake manifold! I didnt think that was normal so i switched it from the intake manifold to a vacuum i found in the carb. Heres a picture of it connected to the intake, its on the left in the picture
Also, unrelated, I have problems with my engine stalling after driving it for an hour and then during an incline if i gas it any it stalls.
Any helps appreciated
PostPosted: Mon Nov 22, 2004 11:23 am
Someone has done a few upgrades......it looks as if your engine now has electronic ignition among other things, and the paint color and layout of the valve cover leads me to believe that you may be running a super six set-up.
Someone can correct me if I am wrong however the normal insertion point for the vacuum advance is at the mainifold side of the base of the carburetor, Have you unhooked, plugged it and checked the timing mark?
Not knowing anything other than what I see on the picture, I would get a threaded insert and plug the manifold and use the vacuum from the carburetor.
You defiantely have a hybrid going there, that really doesn't look like 1965 vintage stuff. Make sure any open vacuum connections are plugged since it appears that his set-up has more ports than you need........
Good luck.
Kevin
PostPosted: Mon Nov 22, 2004 3:17 pm
distributor vacuum advance works off of a ported vacuum source meaning that minute to no vacuum will be present at curb idle until the throttle plate(s) open. if theres vacuum present at a source at idle, its known as a venturi vacuum source.
does the carb have any vac ports that are currently capped off? you can find your ported vac source by uncapping each port one at a time with the engine at idle until you find the one producing no vac. this is where the distributor hose should be hooked to.
PostPosted: Mon Nov 22, 2004 6:07 pm
What you want to do to find where to plug in you advance it to get your self a vacume gage... Hook it up to the carb ports and give the engine a little goose. If the vaccume goes up when the engine revs thats the one you want ... If it drops when you rev the engine it is not the one you want. A vaccume gage is a good tool for setting up the carb so you might want to keep it... It is also good to get your self about 3 feet of vaccume hose and leave it on the gauge it is nice not to be 3 inches from the manifold when your doing carb adjustments (it gets hot there)
Frank
PostPosted: Mon Nov 22, 2004 6:11 pm
it is not a super six with that tiny aircleaner
I do agree with the electronic ignition though.
for the stalling problems I would check and make sure the choke is open all the way and look for vacuum leaks.
PostPosted: Mon Nov 22, 2004 6:14 pm
Also if you look at where the choke rod goes you can tell it is going to a 1bbl not a 2bbl I would also check how close that fuel line runs to the exhaust manifold. You might be vaporlocking after long runs.
PostPosted: Sat Nov 27, 2004 11:54 pm
Yeah, It's definately a 2bbl, thanks for the help guys switching the vacuum hose from the intake manifold to the carb and pluggin the intake fixed the cold start problems i'd been having!
PostPosted: Sun Nov 28, 2004 8:26 am
Glad that worked out.
Not to add to our misery but I would check and clean everything(vacuum lines/dist. advance diapragm) that was previously getting intake air, it is pretty dirty stuff......probably not to good for the distributor vacuum diapragm.......there were probably crancase breather gases/oil getting in the system from the previous hook-up.
