It is currently Sat Nov 28, 2026 10:51 am
PostPosted: Sun Nov 21, 2004 2:05 am
Chris has closed Prolinefuel due to a family illness. Is there any other source for a Weber 32/36 DGEV (2bbl) set up specifically for a 225 slant six, including that manifold adapter?
I know I can buy a 32/36 DGEV from a bunch of sources online, such as the multitude of 32/36s advertised for Jeeps. The only thing is that I do not know if they were tuned for the same engine. With a /6 setup, I wouldn't have to ask for jet sizes. I know I would already have to do something for the kickdown linkage.
PostPosted: Sun Nov 21, 2004 6:09 am
I do not think there is any source that will sell a prejetted 32/36 DGV carb. However, www.carbs.net is a good source for jets.
I'm still playing with the jetting on mine...I'm not satisfied yet. I think I need to install a fuel/air ratio meter to get it tuned to my liking.
'68 Dodge Dart 4dr Sedan
PostPosted: Sun Nov 21, 2004 6:30 pm
The 32/36 weber from a jeep should work just fine on your \6. There is not that much differance in engine sizes to make much differance in the jetting. The jeeps used the same size of BBD when running a 2bbl carb.
PostPosted: Mon Nov 22, 2004 4:41 pm
I just got a mail from racetep regarding my query for a 32/36 setup. They said Proline cannot get the carbs anymore. I was halfway set to wait until Chris's family business cleared up. Is proline down for good or is racetep just trying to cajole me into giving them business?
 Post subject: Stovebolt?
PostPosted: Tue Nov 23, 2004 4:24 am
On another note, how about that Carter/Weber carb from Stovebolt Engine co.? They look similar. It even has an electric choke like the DGEV.
http://www.stoveboltengineco.com/acartp ... oductid=97
PostPosted: Tue Nov 23, 2004 12:21 pm
I bought my 32/36 Weber from Carbs Unlimited at www.carbs.net with the adapter plate to fit the super six manifold. It was supposed to be pre-jetted for the slant six application. In my situation, I have a well-worn slant with 130K miles on it and found the jetting to be on the rich side. I had to buy smaller jets to run the best. They are based on the west coast and sometimes takes a while to ship to me, otherwise I have had no problems.
Brian
Flyin' Brian
"Sixy Beast"
 Post subject: carbs.net
PostPosted: Wed Nov 24, 2004 2:06 pm
OK. I looked at carbs.net too. I was wondering if the Carter/weber on stoveboltengineco.com was roughly the same thing for 280 dollars less. I suppose I'll wait a couple of days longer and then order from carbs.net.
PostPosted: Thu Nov 25, 2004 7:16 am
I looked at the link for stovebolt and that is not the same carb that I have. In fact, it doesn't look like any Weber carbs that I've seen at all. The saying goes...."You get what you pay for."
bmimken
PostPosted: Thu Nov 25, 2004 10:41 am
The Holley 5200 carb that came on four cylinder Pintos, Bobcats, Fairmonts, Zephyrs, K-cars, Mustang IIs, and Capris is identical (literally) to the Weber 32/36. It even will have "Licensed from Weber Italy" stamped into the float bowl bottom. As far as an adapter goes, I ordered mine from Summit. I had to drill out some of the mounting holes but other than that it works. Total cost?: $30 for a reman carb from the boneyard, $30 for the adapter.
PostPosted: Thu Nov 25, 2004 10:07 pm
I bought 3 new 2 bbl electric choke Carter/Weber carbs from Tom Langdon at Stovebolt last year and had him make me a tri-power manifold for them. These carbs are progressives. He has linkage and air cleaners also.
This setup was to be put on my 54 230 ci inline Plymouth motor.
Give him a call and tell him what you are trying to accomplish and he will give you the best advise you will ever get. The jetting should be right out of the box unless you live on Mount Everest. He may be willing to modify a slant 6 aluminum intake to accept duals or even fabricate a tri-power like he did for me. Like anything else, if you want to play, you have to pay.
 Post subject: Got it
PostPosted: Sun Dec 12, 2004 9:43 pm
Finally went and ordered a 32/36 Weber from carburetion.net a week ago. I needed it, too; trying to eliminate an ENORMOUS off-idle stumble I tightened down the carb so unevenly at its base that the thing broke into two pieces and created a huge vacuum leak. crank cran--VROOM, "great, it's different, so I fixed it!... whoa... the idle is kind of high." Yeah, like 2500 rpm high according to my tach/multimeter. After five minutes of tuning I was wondering why I couldn't get it to idle below 1000 rpm when I saw the crack!
So, the Weber will go on tomorrow. Should I drill the manifold PCV hole through that common 1bbl to 2bbl adapter that is sold with every slant six Weber kit? It's a 73, just want to make sure I won't have to do it before I put the carb on.
Edit: In the end I turned away from Stovebolt because Tom told me the Carter-Weber was a much smaller carburetor--made for a 94 cu. inch engine. I would need 3 of them like the above post, a custom setup I didn't want to deal with since I was just replacing a severely worn carb.
