It is currently Wed May 20, 2026 12:43 am
PostPosted: Tue Nov 23, 2004 11:04 pm
My rear end is starting to get some nice vibration, as well as a knock on gearshift(sometimes). anyway, just wondering if i should drive it till it breaks, or is this a saftey issue with lockups and such? its not making any noise, and im pretty sure its stock, '72!
PostPosted: Wed Nov 24, 2004 3:14 am
Are you 100% sure its the rear, not driveline/ujoint issue? Pole vaulting with the driveshaft isn't fun.
I'd look into it before driving it again. Not only for safteys sake, but if you catch the issue now, the repair bill may be less then if you do more dammage. Then again around here a rear end is less then $100 drum to drum.
Check oil level and wheel bearings as well. Last thing you want to see is one of your rear axles passing you when your driving.
PostPosted: Wed Nov 24, 2004 7:19 pm
Yeah, and axle bearings won't give all that much warning. I've had an axle from a 7.25" do just that to me before. Some of the ball bearings were cracked in half!
 Post subject: oiy
PostPosted: Thu Nov 25, 2004 10:06 pm
ok, well my drivline was just balanced and new u-joints. I also changed my fluid in the rear. i just noticed ALOT of play when i had the turd ripped open
 Post subject: k, wel im driving it
PostPosted: Wed Dec 08, 2004 8:33 pm
alrighty, well im drivin it then, maybe some freeway action. maybe ill die. ill post if i do
PostPosted: Wed Dec 08, 2004 9:36 pm
If you die, you might have more on your mind then car troubles, but we'd certianly like to hear from a dead guy :D Hmm... the first haunted message board? You'd defineately have to tell us if the slants were popular among the dead.
