It is currently Mon May 18, 2026 11:08 am
 Post subject: kickdown linkage
PostPosted: Wed Dec 01, 2004 12:57 pm
i recently swapped a super six in my 80 model d-150, and the two barrel linkage is different from the one barrel. i have it wedged back and the shifts are real late. does anyone have the correct linkage for the 727 trans?
PostPosted: Wed Dec 01, 2004 2:12 pm
An alternative if you cannot obtain a rod linkage is a kickdown cable from Lokar, part number KD-2727HT. (Scroll down to the bottom of teh above link for picture).
I have been using this cable on the slant/904 in my '87 D150 for over 3 years with no problems. :)
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Fri Dec 03, 2004 8:48 pm
Check your favorite U-Pull yard for a '77-'79 Aspen/Volare/Diplomat/Lebaron equipped with a Slant.
Look especially for the Aspen and Volare wagons as the two barrel slant six was standard equipment in these models.
Rob everything from the KD rod, to the throttle cable bracket, to the accelerator cable, and you should be set. They will work fine with 727s as well as the 904.
PostPosted: Sat Dec 04, 2004 6:33 am
thanks guys...i mention a /6, and all i get are deer in the headlights looks, and the old "we don't have anything like that around these parts."
PostPosted: Sat Dec 04, 2004 9:12 am
Your yards dont have slant 6 stuff???
OMG! - Around here they ASK me to take stuff! (Sadly I have already done hunting for Super-6s around here and bought all 3 that I found).
:wink:
When in doubt, empty the magazine.
'72 Dart Swinger /6 - My Yard Dart!
'01 Ranger P/U 4x4 X-cab
We buy and sell MOPARTS & Ford Parts!!!
http://www.usironauto.com
PostPosted: Sat Dec 04, 2004 10:19 am
amen..... :lol: MOPAR TOO YAH!!!!!!!!!
 Post subject: Linkage availabiltiy
PostPosted: Sat Dec 04, 2004 6:18 pm
Hey,
I dont know if you are going the (Very good!) Lokar route, but if money is really an object, I can check if anybody locally has any new meat for linkages since last I looked. I can practically hit wildcat mopars with a brick from where I live, and I'm always combing the various yards for parts (since we sell stuff on the WWW all the time). You can reply here or send me a PM/Email if your interested.
PostPosted: Mon Dec 06, 2004 9:13 am
money is real tight from a slow year in the dealership tech field. any help from you guys will be very much appreciated.
jim
PostPosted: Mon Oct 02, 2006 2:52 pm
-S/6
Is this correct or is the correct part number for the A904 a KD-2904HT?
PostPosted: Mon Oct 02, 2006 3:24 pm
At the time I made the original post, Lokar did not make a 904 specific kickdown cable. Since then, a 904 specific kit has become available, so I believe you have the correct 904 specific kit listed. As far as I know, the only difference between the 727 and 904 kits is the length of the cable they include, but I am not sure. There may be some different bracketry included with the 904 kit as well. When I installed, mine, I cut the cable to length, and made my own brackets (and modified some of what was provided in the 727 kit) from scrap metal I had around the garage.
-S/6
PostPosted: Tue Oct 03, 2006 3:51 pm
The part # for a A904 is KD-29004HI from summit racing I have one that I am trying to install on my 73 slant with no luck I have a carter/weber carburetor that the throttle linkage moves to wards the drivers fender. The problem is I am running the kick down on the divers side up by the steering shaft there is no where to hook up the kick down cable to the carb. I don't understand how the cable can connect to push the kick down lever back on the 904 tranny? Thanks for any help I really appreciate it. Jim
1956 Dodge D100 Pick up
power plant 225 slant six
