It is currently Sun Nov 29, 2026 6:35 pm
 Post subject: power steering pump
PostPosted: Fri Dec 03, 2004 7:30 pm
local mechanic has gone through 2 different pumps, and they're not fitting. is there any special model pump that went on a 72 swinger? i already had this same problem w/ the alternator and it ended up being the one off a sixty model cuda. -robert-
PostPosted: Fri Dec 03, 2004 9:21 pm
There are two model power steering pumps, the saginaw (oval filler neck) and the chrysler (heard it called thompson as well, round filler neck). I don't recall which pumps were used for which applicaitons, but once you look at your current one its pretty obvious what type you have and what type you need to ask for.
Check the usual local places, kragen.com rockauto.com autozone.com and if nothing turns up there then go to www.firmfeel.com
 Post subject: Power stearing pump
PostPosted: Sat Dec 04, 2004 7:03 pm
Car Model: 1967 Dodge Dart 270
What you need to do is find out what pump you have on the car now. (Chrysler or saginaw pump), or what pump you plan on installing on the car. The mounting brackets are different. The saginaw pump brackets can be found on many Chrysler and GM cars and trucks. There a dime a dozen in the junk yards.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
