It is currently Sun Nov 29, 2026 3:00 pm
PostPosted: Fri Dec 03, 2004 11:26 am
My (original?) engine is doing a heroic job of continuing to run, but at some point I want to put it out to pasture and put in a rebuilt.
Is "ATK" any good?
Are there other companies out there that sell good rebuilts for older slants (mine's a 63).
OR - are there any Bay Area rebuilders that can do a decent job on the slant?
Other than maybe shaving the head, and putting in a cam, I don't expect to do any other performance mods.
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Sat Dec 04, 2004 9:48 am
There are a lot of different companies / shops that can provide a rebuilt SL6 engine. It is best to call around and get some quotes.
I have never used an ATK rebuild, where are they located?
PostPosted: Sun Dec 05, 2004 12:41 pm
Me, I would never use an off the shelf "rebuilt". For the amount of money that an engine costs, I don't want an unknown factory full of semi-trained apes throwing together my engine with unknown parts; I want to talk to the machinist who's doing the work. There are a lot of options in terms of parts brands and types, as well as techniques, and as the end user of the engine, those options are MINE to specify, not whatever MBA happens to run the parts store I've happened to go into. Those reman engines seldom run well or last.
PostPosted: Sun Dec 05, 2004 4:51 pm
I think ATK has a distributor around here. The cost for a long block is around $1200 echange, not counting shipping.
See: http://www.atk-engines.com/
However, Performance Auto Warehouse (PAW) *used* to have high performance /6 rebuild "kits" for around half that price. I'm not even sure if they still sell them or not.
I'm going to order a catalog from them and find out - see:
http://www.pawinc.com/
Considering what I've spent on go-fast parts for the car over the last 4 years (Offy 2 carb intake, clifford headers, custom flowmaster duals, pertronix ignition, 100 percent new suspension including KYBs, moog everything, urethane bushings, addco bar, MP racing rear springs, cragar s/s wheels, falken H rated tires), it probably does not make sense for me to buy a cheap motor, if it's not going to last as long as a good motor.
I also don't intend to ever sell the car, so amortizing the cost of a motor over the typical life of a slant 6 means that a $3,000 motor (for example) would only cost $75 per year!!!! (3000/40).
Now I just have to convince my better half.
