It is currently Sun Nov 29, 2026 5:57 am
 Post subject: Engine harness question
PostPosted: Sun Dec 05, 2004 7:27 am
I pulled a harness from a '74 Valiant to replace my cruddy/modified OE POS harness and I found two connectors that aren't on my original. I traced them on the schematic in the Haynes manual and they go to the Electronic Speed Switch and EGR Timer. I do not believe my car had these as original equipment. BTW my car is a '74 Scamp. Although my car history is unknown. Another piece of info, the donor had a smog pump as well. So could it be the the items are related? Mine has the egr vavle and the associated vacuum devices. Also I noticed the EGR on the schematic (which doesn't show exact years BTW) has electrical connections at the EGR valve which mine doesn't have. Can I ignore these connections in the harness? Looks to like I can.
Thanks
Sweet Emotion
PostPosted: Sun Dec 05, 2004 9:11 am
The best way to start is to just hook-up want is currently on the car and get that working well.
Mark any "extra" wires for possible use later.
PostPosted: Sun Dec 05, 2004 4:40 pm
Are you sure you didn't get a harness off of a 1975 model year car that was made in late 1974? The 1975 model year used the electronic speed switch which operated a throttle kicker solenoid (a one year only thing on A-bodies). This was used with the then new catalytic converter. The speed switch and throttle kicker was used to hold open the throttle a little extra when the engine was decelerating from above 2500 RPM to prevent a rich fuel mix from going into the catalytic converter which in turn would make it overheat and melt down inside. (Catalyst overtemp protection system)
No EGR valves have any electrical connections. There are electric solenoids used that control vacuum applied to the EGR valve, maybe that is what you are seeing in the schematic?
PostPosted: Mon Dec 06, 2004 7:14 am
Actually your right. The fender tag reads E24 D34 VP41 C5R which is a 75.
So I assume I just leave those connctions unconnected?
Actually there are four other connectors I can't figure out. They are likely related to the EGR system but I would like to know for sure.
1. Near the battery there is a 3 pin connector. Toward the outside of the car. Colors look like Blue Black and Green, hard to tell though.
2. A 2 pin connector right near the bulkhead feedthru. Didn't get the colors.
3. A two pin connector below the windshield washer fluid tank. Looks like Green and Violet.
4. A three pin connector on the right side cowl near the the EGR timer connector.
Another question is where does the AC clutch activate connection come from? Does it go through the bulkhead connector or a seperate grommet in the firewall?
Thanks.
Sweet Emotion
PostPosted: Mon Dec 06, 2004 4:38 pm
Hey Textoad,
I can answer all of those questions. I have the 1975 factory service manual with wiring diagrams and I used to own a 1975 Valiant and had looked up what all those extra wires fit. The car rusted away, I still have the wire harness somewhere.
The next question is... Do the connectors fit your bulkhead connection? Also have to check the possibility that even if it does fit, are all the circuits connected to the same positions or different?
I don't have a 1974 manual to look at, but do have a 1973.
PostPosted: Tue Dec 07, 2004 7:18 am
Excellent questions. After looking closely and doing some continuity testing I discovered the '75 harness is not compatable with the '74. Bummer. The connector fit the bulhead but the wires go to different locations and there appears to be added wires. So I think I'm going to revert back to the old haness and use a few things from the '75 where needed. Argh. Waste of time and money. Oh well. Thanks. :(
Sweet Emotion
PostPosted: Tue Dec 07, 2004 3:39 pm
If you had the wiring diagrams or all the info, I'm sure you could swap wire locations in the bulkhead connector and make it work.
Some of the extra wires may be for the seatbelt safety interock system, not all vehicles of a particular model years used the, it was phased in and out during model years and wiring was changed. I don't recall what other options may account for the extra wires without looking in my book.
PostPosted: Tue Dec 07, 2004 9:59 pm
Craig, I agree. But I don't have unlimited time. They are so similar that I went to the trouble in the first pace thinking those thoughts. But after a few nights of looking and reading I decided to go with the original. The main harness that goes from the bulkhead to the lights and such is really in good shape. The harness that feeds the coil, alternator and AC is the crappy one and after looking at it more tonight, that harness needs to be rebuilt. So I will rewire that one and be done with it. It's simple enough and I think I understand all the connections.
Thanks
Sweet Emotion
Users browsing this forum: No registered users and 14 guests
