It is currently Sun Nov 29, 2026 6:10 am
PostPosted: Sat Dec 04, 2004 7:54 pm
Will a 2-barrel Rochester work on a slant six? Bought one at a car show the other day for 20 bucks. Needs a float. Took it apart and looked at it when I got home and it is extremely simple. How many CFM do they flow?
P.S. would I gain any performance if I swapped out my one barrel holley for a Carter BBS? How about one of those big 1-barrels off of a Jeep 4.0?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sun Dec 05, 2004 12:24 pm
All carburetors mix fuel and air. Some of them do it better than others. Rochester was not known for building the world's best carburetors, and the best reason I can think of NOT to use a Rochester carb is the same reason I drive Dodges instead of Chevrolets.
My preference is for a well-tuned BBS over a Holley 1920 or 1945; others have different results.
There are no "real big 1bbls on 4.0 Jeeps". All the Jeep 4-litre engines are fuel injected.
PostPosted: Sun Dec 05, 2004 1:28 pm
The Jeep 4.0 is just the old 258cid inline 6 updated. They came in 2 bbl and 1bbl versions. The 2 bbl ones are understandably better. I recall seeing single barrel carbs on 258s that looked like Rochesters off 250 chevs. They are not bad carbs,,,they aren t very good either. The Carter YF might be something to try. (single barrel fitted to 300" Fords).
The 2 barrel Rochester has little advantage if any over a BBD Carter.
I used to use a progressive 2 barrel Rochester(1/2 Quadrajet) on a 250 Chev,,,never liked it.
PostPosted: Sun Dec 05, 2004 1:33 pm
Incorrect. The Jeep 258 = 4.2 litres. That is the engine the 4.0 is based on, but they are not the same engine, and there are no carbureted 4.0s.
The 1bbl version used a troublesome Carter RBS (not nearly as good a design as the BBS on the slant). The 2bbl version used a Carter BBD, but again, a different and MUCH more troublesome version than was used on any Chrysler product.
PostPosted: Sun Dec 05, 2004 6:58 pm
sandy,
What was wrong with the progressive 2 barrel(Varajet?) on the 250 Chivie? There was one on ebay a while back that was already set up for a slant six. Looked interesting.
I need to replace my BBS as I have nursed its poor deformed carcass about as far as it will go. I have a spare but it is warped and cracked!
PostPosted: Mon Dec 06, 2004 6:05 am
I think the reason that Sandy didn't like the Varajet was that it was undersized for the 3.7L (225) slant six. It was installed on small engines like 2.5L fours and 2.8L V6s. He said in an earlier post that he got terrible gas mileage with it because the small size caused it to be using the secondary barrel too often. Also, since the Varajet is a different design than the Quadrajet, the Dualjet would be closer to being 1/2 a Quadrajet.
Another problem I've discovered with the Varajet is the lack of rods and jets available for it. Since it was an limited use, OEM-only carb, no one used it for performance applications. I tried searching for jetting parts and only turned up cases of people replacing their stock Varajet with a performance carb. However, just by comparing sizes and since the Varajet was used on 2.8L V6s, it could potentially be used on 170 (2.8L) slant sixes. If you need to adjust the fuel mixture though, you're out of luck.
The 2bbl Rochester (according to Rochester Carburetors by Roe) flows anywhere from 278 CFM to 435 CFM depending upon what size venturis are in it. If you are interested in a 2bbl carb that isn't a Carter, I would suggest you try the Webers that Chris at Proline has for sale (once he opens his shop again). From what I have read already, people who have installed them seem to be quite pleased with them and jetting parts are readily available. If you want performance, swapping one 1bbl for another won't make any real difference. The easiest performance upgrade is the bolt-on super six package. Anything else will require more work.
Incidentally, as far as Rochester carbs go, I am quite pleased with the Quadrajet I have installed on my car. In the spring I will be working on jetting it but it runs pretty good with the original jetting. http://cars.rasoenterprises.com/Carb-Quadrajet.htm
Frank
PostPosted: Mon Dec 06, 2004 6:42 am
Frank,
You are a veritable gold mine on carbs! I am not really looking for more performance. I did call the local carb rebuilder and he told me there were no jets or rods available for the Varajet. The small size of the primary wouldn't be a problem if you could tune the secondary would it? I thought that since Chev used it on the 250cid it might work fine on a 225cid.
The Dualjet is not a progressive is it? I suppose the best solution is the Weber. Either that or get the 4 barrel manifold and then I could grab anything off the shelf and try it!
Thanks for the info.
PostPosted: Mon Dec 06, 2004 7:32 am
There are people here who know a lot more about carbs than I do. You just happened to ask a question I could answer.
Anyway, I was not able find anywhere a source for Varajet metering rods and jets. The Varajet will probably work with your engine but it probably won't work really well unless you could properly jet it. I think, especially now that GM doesn't have anything to do with carbs, it's hard to find any performance parts for Rochesters. Edelbrock is now marketing their version of the Quadrajet so you can still get parts for them.
The Dualjet is a primary half of the Quadrajet so no it isn't progressive.
Frank
 Post subject: Curve ball for Frank
PostPosted: Mon Dec 06, 2004 11:22 am
Frank: Ever hear of anyone running...
...a Motorcraft VV?
PostPosted: Mon Dec 06, 2004 2:25 pm
Some of the folks on the fordsix board have tried them, but most just throw them in the trashcan. A real bad transition to a TBI, is the majority opinion.
PostPosted: Mon Dec 06, 2004 4:03 pm
Yep...a regular fuel-mixing garbagecan, that. I know exactly one person who thinks they're okay, and he thinks that 'cause he used to make a lot of money fixing them at a dealership!
PostPosted: Mon Dec 06, 2004 4:32 pm
Like I said before, I don't really know that much about carbs. Once in while, question comes along that I can answer.
I think the VV (variable venturi) is a great idea that never worked well in practice. As with a lot of things, I don't think anybody really tried to understand how they worked and just replaced them with Holleys. I tried to find out more about them but all I could find was information about getting rid of them.
As far as putting them on other cars, I think it would be even harder to find jetting parts for Motorcrafts than for Rochesters. I don't think it would really be worthwhile even trying to get one to fit on a slant for that reason. I think it would great to know why the VVs kept failing, though. I seem to remember that it had something to do with the diaphragm.
Frank
PostPosted: Mon Dec 06, 2004 4:36 pm
Well, it's a great idea that never worked well for Ford. Other companies had a great deal of success with the concept, though with very different implementation. SU, for instance. I'm going to try out a twin-SU setup on my '62 soon.
PostPosted: Tue Dec 07, 2004 5:57 am
It sounds like the SU carb would be a great alternative to the others we're more familiar with. Those carbs seem to have a large following and there's lots of tuning and rebuilt parts available. How's about writing up a tech article for us once you've got yours to work?
Frank
PostPosted: Tue Dec 07, 2004 9:08 am
*grin*
Yeah,well, that's the optimistic point of view. :shock: I was originally going to run a triple-SU setup, and shipped a couple such setups complete up from Australia, only to find that there'd be no room for the front carb and still keep the A/C in my '62 (see it at http://u225.torque.net/cars/62Lancer/62Lancer.html.) So it's gonna be twin SU's instead (anyone want to buy a triple-SU setup? How 'bout two triple SU setups?). The plan is for Dutra Duals, which will doubtless provide their own challenges in that tight '62 engine bay.
I promise a writeup.
