It is currently Sat Nov 28, 2026 3:56 pm
Post new topic  Reply to topic  [ 44 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Dec 06, 2004 4:18 pm
what do you guys suggest if you want to run and open element air cleaner? what should you do about the tube that runs to the air cleaner?
PostPosted: Mon Dec 06, 2004 4:32 pm
Ditch the tube and go to an open air breather similar to this one. (Pic # 030) Of course the breather on your three hole set-up is rearward of this .
Kevin
http://public.fotki.com/BlueJ/63_dart_man_toy/
PostPosted: Tue Dec 07, 2004 12:42 pm
Wow Kevin - that's a nice 63!
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Tue Dec 07, 2004 2:19 pm
Who said you can't run an open element air cleaner with tube for the crankcase breather? The air cleaner assembly I bought from summit (I think it was a generic unbranded summit brand) has a breather port on the bottom.
It won't fit a 1 barrel w/o an adapter, but it fits the typical 4 barrel/gm tbi body.
PostPosted: Tue Dec 07, 2004 2:50 pm
It's kind of academic...open-element air cleaners are a poor idea.
PostPosted: Tue Dec 07, 2004 3:25 pm
Elaborate Please. :?: I assume the main reason is underhood heat vs cooler air from the front of the vehicle. My truck (with LOTS of room under hood) does not seem to suffer any ill effects from my open element air cleaner (nor open breather), and under-hood heat is neglidgable (again, for my truck, which has a much larger engine bay than cars).
-S/6
PostPosted: Tue Dec 07, 2004 3:27 pm
Open element air cleaner suck in cold air when the engine's cold and wants hot air. They suck in barbecued hot air (and leaked exhaust, etc.) when the engine's hot and wants cold air. Ducted air cleaners are definitely where it's at for performance -- once the engine's warm, cold air markedly improves power and efficiency. And for street driveability, the '70-up thermostatic air cleaner is an enormous improvement over the plain kind.
PostPosted: Tue Dec 07, 2004 3:33 pm
Whoops, must have snuck my edit in while you were typing. ;)
The only thing under hood I cannot touch after the engine is fully warmed up is the header tubes. While the intake does warm up, it never gets hot to the touch, and I will have to get a thermometer to check one of these days, but my under-hood temp does not seem much hotter than outside air (maybe 20*) unless it has been sitting & idling for an extended period.
0.02
-S/6
PostPosted: Wed Dec 08, 2004 6:36 am
VERY nice, clean setup. Hopefully my girl's will look like that one of these days..
PostPosted: Sat Dec 11, 2004 8:18 am
Car Model: 1962 Lancer 770
R9 line is expensive. $25 for 6 feet, thats $4.17/ft. Thats not a great price, but its not terrible either. 5/16" R9 locally here goes for $3-5 as well.
I just did this conversion last night and bought several feet of R9. Of course, I spent $1.18 a foot so I don't know what the big deal is? Actually, you guys just have to wait until you get the new guy at the auto parts store that rings it up as "fuel hose" instead of "fuel injection hose" and buy as much as you can ;-)
BTW in looking at the short rubber line that comes into the fuel pump and goes to the tank, I can see mine is looking worse for wear. It also seems a tad larger than 5/16". Anyone know if its just that mine has swollen over the last 40 years or if its truly a different size. Otherwise I'll just use some of my leftovers for that piece as well.
Also, can anyone suggest a better path to route this hose? I left some extra so i can clean it up later but I had to get it done and in last night.
Thanks!
Menko
PostPosted: Sat Dec 11, 2004 11:52 pm
Menko: I did the same a few years ago with my fuel line (thanks again Dan). I simply zip-tied the fuel line (after the filter) to the bracket on the valve cover that holds the heater lines. Run the line over the bracket (i.e. over the top of it). Leave a little room so that you can slide the bracket off with the line attached for periodic valve adjustment. Oh yeah, I use an open breather because I got tired of replacing air filters with the stock tube from the breather to air cleaner set up. No, this engine has no blow-by....when you have low or zero vacuum situations, oil (or should I say vapers) can get sucked out of the breather. Now my original engine that came in the Satellite...it had blow-by so bad I was changing air filters every week! :shock:
PostPosted: Sun Dec 12, 2004 7:59 am
I'll do as you suggest and esp the part about leaving enough for valve cover removal/adjustment. I'd try to be cool and end up cutting it too short and kick myself later =)
Oh yeah BTW is there a particular ettiquette for posting pictures to save space on the forums? I made this one inline and later realized that it might be frowned upon (or atleast asked to be made smaller). Just curious.
thanks
MJ
PostPosted: Sun Dec 12, 2004 1:25 pm
Inline with the message is fine, but if its a big picture, set the width to 400 or 500 pixels or thereabouts so that it won't cause viewers to scroll horizontally to read messages.
 Post subject: Oil Pressure switch
PostPosted: Sun Dec 12, 2004 2:49 pm
Ok, after replacing all the fuel lines and working on the carb a bit, I tried to tackle the oil change. The filter was more than a bit stubborn, and I ended up having to remove the horn and get a bunch of socket extensions on an end-cap style remover. At the same time, I wanted to replace the switch, and here's where I ran into trouble:
All the switches spec'd out for that car at my local place have 1/8" threads. When I pulled out the old switch, the threads were much larger (not sure what the exact size was). Is it ok to use an adapter to mate the smaller switch to the block? Or does someone know of a part # that will actually fit? I searched through the catalog they had and couldn't find anything that would match up.
I ended up with the damn adapter and some teflon impregnated thread-sealant to hopefully prevent leaks. But it seems half-assed and wrong to me. Any help is appreciated. I'm a newb (in case the name didn't suggest it) so I apologize for any ignorance in advance!
MJ
