It is currently Sun Nov 29, 2026 6:36 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Tue Dec 07, 2004 9:23 am
"What was wrong with the progressive 2 barrel(Varajet?) on the 250 Chivie? There was one on ebay a while back that was already set up for a slant six. Looked interesting. "
My opinion on the Varajet used on a 250 in a 6500lb truck. It was a stock carb on 1980? Chev trucks . The setup included a very nifty split manifold and Y pipe that functioned very well. The 6/Varajet setup was an attempt to achieve better gas milage in a large truck. I got 11.5 compared to 10 with a carbed 350. The same basic truck with a TBI 350, headers and split duration 262/268 cam and performer intake gets 13.5....and about 200 ft/lbs more torque.
The varajet ran well but most of the time I was in the secondary,,,,when I revved it to the redline the carb leaned out causing detonation.
This carb is overly complicated.
I use a 65 318 BBD on our slant . It is probably the easiest, most economical carb I have ever run (mileage and maintenance cost).
I still plan on a TBI setup from a 4.3 Chev for the same reason I went TBI in our GM products. WAY better mileage and easy starts, ability to run big cams in winter. Without an oxygen sensor part throttle AFR is just a guess.
