It is currently Sat Nov 28, 2026 1:17 pm
PostPosted: Fri Dec 10, 2004 9:20 am
When I do my supersix conversion I'd also like to get rid of the choke stove setup and put an electric choke control on my carter 2bbl.
Anyone ever try this,,, or know were I could buy a universal fit choke control.
I realize i'll have to adapt it, and make a mount for it, but I thought it would be a big improvment over the choke stove setup.
Thanks
Scott
PostPosted: Fri Dec 10, 2004 9:36 am
I have run electric choke conversions in the past. I probably won't do it again on a setup for which an original-type choke remains available (i.e., 1bbl or 2bbl on a slant). An electric choke is not a big improvement (or any improvement at all) over a properly-functioning stove type choke. What specific improvement are you hoping to gain?
PostPosted: Fri Dec 10, 2004 9:59 am
Well basically i was thinking it would be much eaiser to adjust.
Isn't the only way to adjust the stove type by bending the rod to alter its length ?
PostPosted: Fri Dec 10, 2004 10:12 am
If everything's hooked up and working correctly and you're using the correct-thickness carb base gasket, there's usually no need to adjust the choke thermostat. But if for some reason you will require the ability to adjust the choke's spring tension, then yes, in that case some of the electric setups will provide that. But, be advised most of them require a considerable amount of fiddling and tweaking before they work "all the way right".
PostPosted: Fri Dec 10, 2004 1:03 pm
the gasket you need is about 1/4 -3/8thick you can find the fellpro part # in the parts search on the main page.
PostPosted: Fri Dec 10, 2004 8:08 pm
If you can find a Jeep vehicle with a Carter BBD it should have an electric choke from the factory. I've seen them on AMC cars as well.
Dart68
PostPosted: Fri Dec 10, 2004 8:09 pm
N/A, the Carter BBD on the AMC/Jeep vehicles is of a substantially different design, with the choke thermostat integrated into the airhorn. Not only is it not interchangeable, but you wouldn't want it even if it were; the AMC design variant of the BBD is highly problematic and unreliable.
PostPosted: Sun Dec 12, 2004 11:22 am
Thanks for the info. I didn't know that. I only noticed that they were Carters with electric chokes, never compared them to a Chrysler make BBD.
Dart68
Users browsing this forum: Google [Bot] and 10 guests
