It is currently Sat Nov 28, 2026 3:55 pm
PostPosted: Sat Dec 11, 2004 11:36 am
Hey there
My slant is pinging over 2500 - 3000 rpm when I full throttle it. If I go gradual on the gas pedal, it wouldn't ping as it keep reving up, but if I step on it it would ping.
I have a recurved dist (about 9 R) and a 5 vacuum can, the two springg are light but one still has a loop. Would that be due to distribution or maybe something else is going around?
stock electronic ignition, NGK japanese spark plugs gaped .40, good 8,5mm silicone wires, good coil.
No pinging or power loose below 2500-2800 under any trhottle opening.
Initial timing is about 13 degrees. My cam is custom, yet mild and very streetable. Head shaved .40 block shaved .25 or so. Steel gasket. One overheat last week before I went to twin electrofans. (Radiator top tank blown and threw all the water out, stopped, refilled it and leaved w/o cap, drove 20 blocks to my garage and took the rad out for resolder after 2 hs cooldown.
No oil consumption even after the heatup.
Any inputs on this case? thanks in advance
Juan
PS: carb is a holley 1922 (richer and more flow version of a 1920, customized in argentina to replace the carter BBD that came with our supersix setups) main jet #59.
Juan Ignacio Caino
PostPosted: Sat Dec 11, 2004 11:38 am
kinda goes heat on traffic jam, or if I have no mercy on the poor thing in the city (heavy accel and stop frequently.
Juan Ignacio Caino
PostPosted: Sat Dec 11, 2004 3:14 pm
what is your total timing? Your total timing sounds too high to me crank it down to about 4-5 initial and see what happens
PostPosted: Sat Dec 11, 2004 11:05 pm
I would back the inital timing back to 8* or 9* initial, and if it still pings back off another 2-3* or install a heavier advance spring.
Another option is to try premium fuel (if you aren't already). With .040 off the head and a steel gasket your slant is somewhere around 9:1 compression.
Backing the initial timing off will likely help with the overheating as well.
-S/6
PostPosted: Sun Dec 12, 2004 7:31 am
My comp is 9.2:1 according to some measurements a friend did for me.
with 4 initial is kind like playing pool with a rope... just lazy
fuel i'm using is 100 octane... so i figure why not kickin the advance above 10 deg.
can some trouble cause the car to keep on ported vaccuuming the can on the dist at higher RPM?
and thanks on the temp related timing thing. I always thought it was backwards (retarded=heat advanced=cool)
could it be... :cry: blown head gasket???? :cry: :cry: :cry:
Juan Ignacio Caino
