It is currently Sat Nov 28, 2026 5:11 am
PostPosted: Fri Dec 10, 2004 6:18 pm
Does anyone see a problem with this? I want to weld an o2 bung on my clifford shorty header but don't want to take it off the car. The collector gasket I don't care about, but I didn't know if I should be worried about the gasket mating it to the head.
PostPosted: Fri Dec 10, 2004 8:41 pm
If you can, run the car so the header is warm before you weld it. That way it will cool off a lot more evenly. :shock:
PostPosted: Fri Dec 10, 2004 8:55 pm
Thats a good idea. I don't plan on doing the welding myself, I'm going to take it to a muffler shop and have them do it. The last one they did for me on the tailpipe was $20 so I'd rather do that then make a welding boo-boo.
PostPosted: Fri Dec 10, 2004 9:50 pm
Also, most welding shops will use a stick welder which has a larger heat effected zone and a longer heat up and cool down time. this makes the weld more pliable and less likely to crack under vibration or expansion and deflation. Mig welding will make a strong but brittle weld which isn't ideal for the exhaust.
PostPosted: Mon Dec 13, 2004 1:19 am
Disconnect the battery when welding.
PostPosted: Mon Dec 13, 2004 10:22 am
Also disconnect / isolate any electronic ignition box you may have.
MSD says to do this if you use any type of electric welder, anywhere on the car.
Users browsing this forum: Google [Bot] and 11 guests
