It is currently Sat Jul 18, 2026 12:19 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Sun Dec 26, 2004 9:26 am
It's been so long ago I don't remember which kits or specifics about the installation (but the '68-'72 application had to be a misprint, columns changed in 1970 when the ignition switch was relocated there), but I can assure that in my case, I did install it correctly using whatever was supplied in the kit. The only thing I distinctly remember was that my hazard switch (knob) prutruded a bit too far, and I trimmed it back carefully to be more in line with the column housing.
Good luck to all,
D/W
If it ain't broke, fix it!
