It is currently Mon Jun 01, 2026 6:11 am
PostPosted: Sat Jan 01, 2005 4:59 pm
Put the water temp sending unit on my neighbor's slant and it hit me that I couldn't recall installing the oil pressure sending unit. I've looked all over (at least where I can see with the header, intake, carb, a/c comp, p/s pump, and other stuff on there now).
Just where is it on a 225? I've been through my 67 service manual, but it doesn't show it anywhere.
PostPosted: Sat Jan 01, 2005 5:24 pm
It is just below the oil filter on the filter mounting point. Kind of hard to miss it if you get under the car and look up.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sat Jan 01, 2005 5:26 pm
Thanks.
PostPosted: Sat Jan 15, 2005 11:45 am
Ok, so the pressure sending unit is actually on the oil pump, and not the block itself, right?
The new oil pump has a bolt coming out of the "point" that is just below the filter mounting pad. The bolt is replaced with the sending unit, correct?
PostPosted: Sat Jan 15, 2005 12:01 pm
Correct.
