It is currently Fri Jul 17, 2026 5:38 am
 Post subject: up shifting
PostPosted: Tue Jan 04, 2005 11:25 am
does my kickdown linkage need a return spring?
the lever on the tranny goes all the way back @WOT.
but does not return?
kinda sticks all the way back.
it kicksdown to 1st then to 2nd but does not up shift back to 3rd(drive).
PostPosted: Tue Jan 04, 2005 11:32 am
nevermind id say this anwser my question
http://www.slantsix.org/forum/viewtopic.php?t=11250
PostPosted: Tue Jan 04, 2005 11:44 am
I installed a spring on the trans lever on my truck because the lever was "lazy" in returning to light pressure (I am using a Lokar KD cable). The trans lever will come back immediately now, but the spring on the trans end does increase the effort to press the accelerator down. Adding a spring at the trans is essentially the same as adding an additonal spring to the throttle linkage at the carb (with the cable KD at least).
-S/6
The "Silver Bullet"
87 Ram D150
