It is currently Mon May 18, 2026 4:28 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Fri Dec 31, 2004 6:09 pm
Yes, it will work. I would try and make sure that its a rebuilt nippondenso, not a cheap copycat because apparently lots of mimmicks are coming from overseas.
PostPosted: Fri Dec 31, 2004 6:11 pm
Be careful with the eBay starters; virtually all of them advertised with a buy-it-now price of $70 or $80 or so are Chinese copycat shît that won't work well or last long.
Yes, the V8 starters also work on the slant-6.
The grinding phenomenon is a failing starter drive unit.
PostPosted: Fri Dec 31, 2004 7:11 pm
As pointed out on the mini starter thread a few below this one, you can find $70 rebuilds using oem parts on ebay that specifically say they are rebuilt oem nippondenso's not cheap imitations.
PostPosted: Mon Jan 03, 2005 7:24 pm
one more thing.
gear reduction and mini starters are they the same thing? i know someone who said you have to heat wrap gear reduction starters.
i said if they are both the same thing then i think its a bunch of bull****.
im not sure.
PostPosted: Mon Jan 03, 2005 7:58 pm
No they are not the same thing. Both the original mopar starters and the nippon denso starters use a 4:1 gear reduction but are 2 different starters but interchangable for our slants.
You don't need to wrap them for heat protection unless your exhaust comes very close to it, gear reduction or not.
PostPosted: Thu Jan 06, 2005 5:44 pm
ok, i think i figured out the problem.
I read if you crank over the starter at below 9 volts it damages them. I believe my volt regulator is going out, the volt on my meter isnt stable.
PostPosted: Thu Jan 06, 2005 5:58 pm
Site Admin
I agree about the poor quality of rebuilt parts these days. I have bought starters that are dead off the shelf. Now I take my starters and alternators to an independent rebuilder. They always work and the cost (here) is about the same, maybe a bit more if there is lots wrong with it. I definitely recommend that route. Also, if you suspect overheating, make sure that there are no exhaust leaks between the manifolds and around the pipe flange. A little leakage there will ruin a starter in no time as it "cooks" the enamel coating over the internal windings.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Tue Jan 25, 2005 8:22 pm
thanks everyone for the help, i think ive got it figure out.
thanks again
Users browsing this forum: Amazon [Bot], Google [Bot] and 8 guests
