It is currently Thu Nov 26, 2026 10:14 am
PostPosted: Thu Jan 06, 2005 8:59 pm
I've been looking for a rebuild kit for this carb and found a Nihas brand kit for 26 dollars. I've been told Nihas is a Borg Warner subsidiary. Any suggestions on brand? I read on a site somewhere to try and get a Holley kit but I am not able to find one yet. Also I read that there is a "trick Kit" for carbs but haven't found one for this carb either. Appreciate the help.
Thanks.
Sweet Emotion
PostPosted: Fri Jan 07, 2005 11:01 am
What I ahve seen is that the cheap kits don't have many "metal or rubber" parts in them, they tend to be gaskets / instructions (paper) only.
A "paper only" kit may-be OK for a newer carb where you just need to look inside and check all the settings and make sure all the inturnal plugs, seals and gaskets are doing their job.
PostPosted: Fri Jan 07, 2005 6:46 pm
Thanks Doc. I got lucky today and found a real Holley Rebuild Kit from a local performance shop. Of course I have no idea how long it's been on the shelf but it's sealed and looks clean on the box.
Sweet Emotion
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 22 guests
