It is currently Fri Nov 27, 2026 12:49 am
 Post subject: Comp Cams Kit
PostPosted: Sat Jan 22, 2005 1:28 pm
those of you running comp cams, did you buy the cam alone, cam and lifters or the whole kit? im looking at cams to i was curious what others had done.
PostPosted: Sat Jan 22, 2005 2:26 pm
I bought cam and lifters because my head already had good springs on it. :shock:
 Post subject: comp cams
PostPosted: Tue Jan 25, 2005 12:52 pm
i bought a used comp cams 252s off ebay(!) and i called comp cams and they said i could use it with my original springs and lifters. since my engine had less than 15,000 miles on a fresh and complete rebuild i wasn't worried about getting new lifters or springs. the 253s is slightly above stock though. if you want anything larger i would suggest getting the 340 springs. i have heard that they work real well and are a direct replacement.
zedpapa
soon to have 5 gears!!!
PostPosted: Tue Jan 25, 2005 3:34 pm
what about the timing chain they show coming in some of the kits? anyone ever used one of those?
PostPosted: Tue Jan 25, 2005 8:43 pm
I used the Comp 252, used a matched set of stock springs (went through a can of them to find a uniform set), at the time lifters were getting hard to come by so I ended up having to buy a small block set of mech. lifters (so now I hve extras...)
The best timing set I've seen yet is the one Cox Brothers offers, especially if you are degreeing the cam in.
