It is currently Tue May 19, 2026 10:43 am
 Post subject: slant six hp
PostPosted: Sat Jan 22, 2005 9:46 pm
hey ive got a '74 slant six ... now ive heard its supposed to get about 145 hp....with a .30 over bore and a 2 barrel carb and headers....how much hp do you think it will get?.......
also...if i put it in a 78 aspen...how fast should it run the quarter mile? 0-60?
thx
PostPosted: Sun Jan 23, 2005 2:43 am
what about the head? shaving just .040 off a stock head raises compression on a stock slant six from 8.7:1 to 8.9:1. also porting.
It all depends on how far you want to get into it plus free time:
With a decently built head, headers (with a single 2.5'' or dual 1 7/8'' pipes depending on your headers), a supersix intake setup, elecrtic fans (frees ~15hp), elecrit ignition, new timing chain. you could get 220hp +\-. None of this will work though unless you have a "Tuner Slapper" sticker on your car.
another power free-er-up-er is the rear end. a simple gear swap and give you lots of low-end pop (great for slapping tuners at the light or fast 0-60's). if you any accesories running off the car like power steering or A/C, take them out (or at least remove the belt for them). those use hp to run. "ohh boo hoo its hot, or its too hard to turn the wheel unless im moving: roll down the window and use yer muscle"
all this can be gotten at a pick-n-pull or similar junkyard for less than 250$
except for that whole head part, thats up to you. with these changes you could have a high 16 second tuner slapper.
PostPosted: Sun Jan 23, 2005 2:44 am
a 50hp No2 shot could be fun too for a stock sl6 ;)
PostPosted: Sun Jan 23, 2005 9:36 pm
Or, stick a 200 horse shot of nitrous and scare the heck out of the person your racing when you engine suddenly explodes :twisted:
Guess you should do that in a car you don't like first though...
PostPosted: Mon Jan 24, 2005 7:47 am
Before you get too excited about the potential of the 225 remember that the 145HP figure was the original pre 1972 SAE Gross Horspower amount and not the SAE Net Horsepower in use today. The net amount is aproxiamtely 80% of the the old gross figure. That net horspower is measured at the flywheel with all engine accessories attached (Alternator, P.S. pump, AC etc.) So your starting point in today's Horsepower is really about 115HP assuming that Chrysler wasn't stating "Advertised" HP. In truth I'll bet the average 225 that came off the line made no more than 135-138HP which would put you down to 110 Net. That 110 Net translates to about 90 at the rear wheels and that's down into Honda Civic territory :(
Even the original Hyper Pack 225s were probably only making just over 200 Gross HP (160 net) so if you get your engine to that point without the juice you'll be doing pretty good. Good luck with your project.
Here's a good webpage that discusses the changes in horspwer ratings.
http://neptune.spacebears.com/opine/horsepwr.html
"Former Owner" of '65 Barracuda, 225, Auto, MP 2bbl intake, MP cam, Dutra Duals. Presently Moparless.
PostPosted: Mon Jan 24, 2005 9:23 am
My 68 dart stock 1bbl made 76 hp on a chassis dyno I dont remember the rpm though. Trying to put it back together now so I can get a new hp figure with all the work .
PostPosted: Mon Jan 24, 2005 3:58 pm
With a straight six, torque is your biggest virtue, not horsepower. Even with 2.76 gears, my Duster is a lot quicker off the line than my girlfriend's Civic (which isn't much of a car to start with :? ). To me torque is much more important than horsepower because torque is the stuff you feel when taking off from a stoplight.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: 69 dart
PostPosted: Sat Jan 29, 2005 6:50 pm
i had a question. I have a 69 dart and it has a 225 slant 6 in it. Does anyone know how much hp it has?
PostPosted: Sat Jan 29, 2005 7:04 pm
About 100 at the crank.
See: http://tinyurl.com/72cgx
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Mon Jan 31, 2005 1:20 pm
stock head with the 390 Holley it had on there at 8.2:1 CR. The engine put out 101 hp @ 3000rpm (thats 80mph)
Now that I have a 4 bbl edelbrock 500 and it breathes alot better, redoing the engine and milling it .100 and getting 9.2:1, after doing my head with a 5 angle valve job 1.70/1.40 valves, and blending the bowls and mild porting, the engine should be well over 230hp.
Same cam profile MP .436 cam on the first engine, Isky .438 on the new motor.
Next modification; Nothing, im happy with her as my daily driver
 Post subject: Mine
PostPosted: Mon Jan 31, 2005 2:45 pm
72 short block (used and abused)
mild head porting with stock valves and fresh springs
stock cam
stock non lockup 904 transmission
supersix with BBD carb
Hardly any exhaust, but stock manifold
stock 7 1/4 highway gears
slightly bigger than factory tires (uuuugh, but not for long)
really nice electronic dist with custom advance curve.
No pollution anything
no weight reduction
power steering
power brakes
All this strapped into a 1980 dodge aspen 2 door and only 1 day at the track to test and tune = best time of 18.96
I suspect that an electric fan, remove power steering, weight reduction, smaller tires, 2.91 sure grip rear, and a rebuilt shortblock will have me in the mid 17s by late summer. (it's all sitting in my garage if I can just get a few free days to install it all. :wink: )
A little better cam in the shortblock might even do better, but you get the idea. May not beat every tuner on the block, but it's very consistant and bulletproof.
1980 Aspen 225 super six
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 4 guests
