It is currently Thu May 14, 2026 3:10 pm
 Post subject: 360 head/intake gasket?
PostPosted: Thu Jan 27, 2005 6:45 pm
I know its a non /6 question but...... I am just finishing rebuilding the 360 in my truck. When I put the performer intake manifold on the c shaped hole in the head just above the heat crossover is outside the manifold and in the open. No intake gasket Ive found covers this hole. Do I need a special gasket or blockoff? Thanks in advance..... I'm gonna try and install it this weekend so any help would be appreciated............
PostPosted: Thu Jan 27, 2005 6:49 pm
Car Model: 62 Lancer GT
Had trouble logging in with above question.
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Thu Jan 27, 2005 7:52 pm
That "C" shaped hole stays open. it is a blind hole. Just an airspace between the exhaust cross over port in the head and the rest of the head.
Same hole is open on my 318 too. If you spill water down there and run the enigne then the water boils and pops and shoots out of those holes!
PostPosted: Thu Jan 27, 2005 8:07 pm
Thanks..Do you know what its purpose is?
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Thu Jan 27, 2005 8:34 pm
Since exhaust gases flows thru that hole, I would suspect it is for cooling purposes.
PostPosted: Fri Jan 28, 2005 4:53 am
My guess is just an air gap to keep from transfering exhaust heat into the head above that area. Otherwise it would cook the oil under the valve covers.
PostPosted: Fri Jan 28, 2005 6:24 am
Thanks..I guess were all thinking the same
1966 Dart GT
62 Lancer GT
B Body 8 3/4
