It is currently Fri Nov 27, 2026 4:36 pm
PostPosted: Mon Jan 31, 2005 11:51 am
Item#7950864465 on ebay. A nice looking set of 3 OER Carbs
(Jap Weber copies?) on a slant six manifold setup.
Anybody know about this- particularly the manifold?
I don't want to spend the $600 + right now, but it might be nice to
get a manifold and play- maybe with some Webers.
PostPosted: Mon Jan 31, 2005 12:06 pm
For "Coolness factor" it gets a 10
but for drivability, its probably way to much carb for the average slant 6.
PostPosted: Mon Jan 31, 2005 1:11 pm
Out of curiosity, how much are those carbs rated in cfm and where the heck do you put the air cleaner?
PostPosted: Mon Jan 31, 2005 3:44 pm
No, each cylinder gets 1 barrel - just like the stock motor.
PostPosted: Mon Jan 31, 2005 3:45 pm
What about the manifold? Is it a one-off, ot is somebody making them?
PostPosted: Mon Jan 31, 2005 3:49 pm
Theres another thread on this setup http://www.slantsix.org/forum/viewtopic.php?t=11252 I dont know flow or anything except that they are 47's which is pretty big. The may be dellorto or solex carbs or some other knockoff ??? dunno really, I wonder if they would take weber jets etc and/or if parts are available for them.
You get one barrel per cylinder with a mixture screw for each barrel (well with weber sidedrafts you do anyway).
For air cleaner you'd have some options. You could use one long air cleaner (something like this but with one more carb spot http://www.rdent.com/images/itg.jpg ), one aircleaner for each carb (like this, this is a hemi 6 Charger E49 engine http://www.chargerclubofwa.asn.au/Visit ... zrts02.jpg ) or use the foam socks and put one on each trumpet (so six of these http://www.bavauto.com/assets/product_i ... t/u400.jpg ).
65 Dart GT Convertible
http://www.displacedkiwi.com (click on /other then the dart icon, then whatever you want!)
PostPosted: Mon Jan 31, 2005 4:21 pm
I'm GUESSING that this is being offered for sale by:
http://www.piercemanifolds.com/contact.html
It's a company out of Gilroy that sells weber stuff.
k
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Mon Jan 31, 2005 4:23 pm
Here's the same photo as the ebay listing at:
http://www.piercemanifolds.com/Images/C ... 14-OER.htm
PostPosted: Mon Jan 31, 2005 7:27 pm
:lol:
...just like stock ol' Porsche or Ferrari...
:lol: :lol: :lol:
PostPosted: Tue Feb 01, 2005 9:09 am
I found it strange that he says "not Weber" but won't say what it is. The usual "other" side-draft is Dell'Orto DHLA or Mikuni PHH (neither offered in 47mm TIKO), but there have been knock-offs made by smaller companies (Claude? Berg?).
On the down-side, you need a lot of parts and time to get the jetting right but it should work very well on a mild motor.
PostPosted: Tue Feb 01, 2005 5:22 pm
I posted a question on ebay to the seller - they are "OER carbs made in Japan."
I think OER means "original equipment reproduction."
PostPosted: Tue Feb 01, 2005 8:38 pm
They may be S&S Carbs, which were made in Japan and used weber parts.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
