It is currently Sat Nov 28, 2026 7:13 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page 1 2 3 Next
 Post subject: Roller Chain
PostPosted: Tue Feb 01, 2005 6:58 am
OK, fellows. Where was it I needed to go to get a roller chain set for my /6?
D/W
If it ain't broke, fix it!
PostPosted: Tue Feb 01, 2005 7:28 am
NAPA-
Chain = 9168
Crank sprocket = S339
Cam sprocket = S338
 Post subject: Cox Brothers....
PostPosted: Tue Feb 01, 2005 7:35 am
Do a search and look them up, they have a couple to choose from.
PostPosted: Tue Feb 01, 2005 8:58 am
Dennis Check out this link too.
http://www.slantsix.org/forum/viewtopic.php?t=11426
PostPosted: Tue Feb 01, 2005 10:06 am
Thanks for the linx... Hey, racers, I've got the 264 Comp cam installed straight up right now... 60' times a little slow, you know the deal - should I try advancing my cam while I'm swapping chains? Is this gonna slow me down on the top end significantly?
D/W
PostPosted: Tue Feb 01, 2005 10:07 am
NAPA-
Chain = 9168
Cam sprocket = S338
Timing chain for a Chevy 454 ($20.49)
Generic Crank Sprocket ($33.49)
Generic Cam Sprocket ($33.49)
Total $87.47, all prices from Napa Online.
Dan, are these peices the same dimentions as factory gears, or are they slightly larger or smaller? How long did it take to find this 'needle in a haystack' combination of parts?
Thanks for the info! ;)
-S/6
PostPosted: Tue Feb 01, 2005 11:08 am
Just curious - what are the advantages of a roller timing chain?
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Tue Feb 01, 2005 11:26 am
Less friction/wear, less stretch over time, and in my case, the part-store replacement non-roller chain I'm running on the Duster is noisy as hell at certain RPMs. I'm gonna do the modification to the galley plug to get more oil to the chain while I'm in there, too.
D/W
PostPosted: Tue Feb 01, 2005 12:11 pm
I say advance the cam 2-4 degrees and see how it goes. From several racers, I've heard that advancing the cam over factory spec helps almost across the board with little drop at high RPM. I have not done experimentation on this myself, I'm afraid. I think the cam grinder companies spec V8 centerlines on Slant cams, and the Slant probably likes a little more cam advance.
PostPosted: Tue Feb 01, 2005 6:07 pm
The Comp Cam 264 is ground with a built in 4* advance, I think it installs at 106*. This means, on a stock cam with the gear dots lined up, the cam is in at 110*, the Comp 264 with the dots lined up, will be in at 106*. Of cource, because of tolerance stacking, all cams should be degreed in.
Slant Cecil
PostPosted: Tue Feb 01, 2005 6:17 pm
Hmmmm, I'll have to dig out the spec sheet and see...
D/W
PostPosted: Thu Feb 03, 2005 6:09 pm
Car Model: 62 Lancer GT
Doesn't someone make a single roller chain for the six?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Thu Feb 03, 2005 6:34 pm
Why would you want that? Just curious.
D/W
PostPosted: Fri Feb 04, 2005 12:55 pm
Nuts to all that chain nonsense.....I want dual idler gear drives for mine! :twisted:
PostPosted: Fri Feb 04, 2005 3:13 pm
Hey, yeah. Who's got that picture again?
