It is currently Wed Nov 18, 2026 6:22 am
 Post subject: A500 Tranny
PostPosted: Thu Feb 10, 2005 12:19 pm
are there mods that have to be made to the transmission crossmember to run a A500 in an a-body? i know about the adapter plates and the tranny tunnel but i cant find any info on the mods that might be required on the crossmember. can anyone enlighten me?
PostPosted: Wed Feb 23, 2005 2:22 pm
I hope to get time to write an article on this soon. Yes, you need to cut out most of the upper X and rebuild it, and build a new lower X as well. I started the lower X with my original lower X ears and used some 1.5X2.5" box tubing to extend it down a bit, then modded the A500 rear mount to use a PolyU chevy trans mount.
