It is currently Fri Nov 20, 2026 1:45 am
 Post subject: Quick rearend ?
PostPosted: Thu Feb 10, 2005 10:32 am
I need to find out how to tell what size rearend I have. It is a 63valiant, I don't know how many different sizes they made or how to tell by looking.
What do I do? :?
Thank You
crooked6
PostPosted: Thu Feb 10, 2005 11:14 am
count number of cover bolts and post back. ron
PostPosted: Thu Feb 10, 2005 1:57 pm
It is a 10 bolt rearend. If it is stock, what ratio is that?
PostPosted: Thu Feb 10, 2005 2:27 pm
Then you have a 8 1/4" rear.
Look for a little tag under one of those bolts.
It has the ratio stamped in it, or something else...
PostPosted: Thu Feb 10, 2005 7:58 pm
I hate to say it, but if it had a tag it is long gone by now. The car is old after all. Anyway, my search continues for this ratio. I need this because I'm am trying to buy the proper speedogear to the tranny. I need rearend ratio and tire diameter, the latter being easier to figure out
PostPosted: Thu Feb 24, 2005 1:05 am
jack the rear end up turn the wheel 1 full turn count the number of turns the driveshaft turns. 2 and 3/4 turns 2.73:1 almost 3 turns 2.94:1
if both wheels turn the same direction you have a posi rear end .
you can jack up 1 side and turn the up wheel 2 turns and count shaft turns
73 swinger holley 5200, 2 1/4" exhaust .030 over new pistons , cam, .010 under crank. stock everything else. 1/4 mile about a week. 0-60 around 15 sec.
PostPosted: Mon Feb 28, 2005 10:11 am
If you wanted to change the ratio in your diff, contact "Randy's Ring and Pinion".
'78 Volare 225
'67 Charger 318
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
