It is currently Sun Nov 29, 2026 3:00 pm
PostPosted: Tue Feb 15, 2005 1:24 pm
Going with the carb adapter and a 2 barrel Holley 5200 (Weber 32/36 clone, sort of) which side should the primary go towards?
The engine (passenger) side closer to the engine or away from the engine?
The Weber book I have shows a detail of straight six carb orientation and the primary is closest to the engine. But the Holley I have has the linkage closest to rear which puts the primary to the outside away from the engine.
I suppose it could be mounted the other way but would require more work on the linkage arrangement. I already have it set up with the primary away from the enigine.
Also how is the Carter for the Super Six set up?
Thanks. Sorry for so many posts but I'm trying hard to get this car on the road.
Sweet Emotion
PostPosted: Tue Feb 15, 2005 1:37 pm
Can't answer your "Which way round?" question, but the standard Chrysler 2bbls (Carter BBD) work great.
PostPosted: Tue Feb 15, 2005 2:11 pm
The carbs for the super six setup are not "primary and secondary",
both barrels open together.
For your webber setup, I would think you could go either way, but probably which ever makes it easiest to hook up linkage.
