It is currently Mon May 04, 2026 8:38 am
PostPosted: Fri Feb 18, 2005 7:37 am
We're re-installing the front brake hoses on Aaron's Dart and can't find the "U" shaped retaining clips that hold the hoses in the tabs on the frame. There are no 70's model cars in the local wrecking yard to rob the clips from. Do any of you have a part number I could try at the dealership? I've tried the "HELP" section at all of our parts stores, but no one has anything even close.
Thanks for any help,
Jerry
p.s. Yes! We are actually starting to put things back onto the car. I'll begin to post updates on our progress soon.
PostPosted: Fri Feb 18, 2005 8:17 am
How many do you need, and where to send?
D/W
If it ain't broke, fix it!
PostPosted: Fri Feb 18, 2005 8:34 am
We need two front hose clips. If you have extras available, I would be happy to pay for them and postage. Funny how such a little thing like these clips can jam up the works. :evil:
Jerry Landes
420 Skyview Circle
Troy, TX 76579
 Post subject: Parts Store
PostPosted: Fri Feb 18, 2005 8:37 am
I got those in the "Help Parts" section of a local parts store for a couple bucks.
PostPosted: Fri Feb 18, 2005 9:07 am
Mine are free! If you need two, I will send two, if you need four I will send four, etc. But I like to keep spares around, too! So you are missing only two? Verify, and it's in the mail in a few moments.....
D/W
PostPosted: Fri Feb 18, 2005 9:08 am
Already went to three stores with no luck. Do you happen to know which one you found them in?
Jerry
PostPosted: Fri Feb 18, 2005 9:17 am
Jerry,
I have two clips in an envelope, ready to send... Should I drop them in the mailbox?
D/W
PostPosted: Fri Feb 18, 2005 9:43 am
Yes, please. Thanks very much. :D
Jerry
PostPosted: Fri Feb 18, 2005 10:01 am
The mail(wo)man just picked them up. :)
D/W
