It is currently Fri Nov 20, 2026 12:03 am
 Post subject: Attn:Dart270
PostPosted: Fri Feb 25, 2005 8:38 pm
How are you doing? Have you checked this site out? www.transmissioncenter.net They have vacuum and oil pressure switches that will eliminate the need for toggle switches to activate the lock-up and overdrive features of the 518 transmissions. I plan to make contact to find out if these also cover the A-500 transmissions. Found this link in Car Craft's What's Your Problem section of the April 2005 edition.
Hope you find this interesting.
Dart68
PostPosted: Sat Feb 26, 2005 6:18 am
I haven't seen a more difficult to use webiste in a long time.
This is what happens when web designers start using meth.
Here is the link to their A500 page
http://www.transmissioncenter.net/dodge.htm
PostPosted: Sun Feb 27, 2005 2:09 pm
Looks like a pretty good and simple system, with cheap parts. I have thought of building an electronic circuit to do this, but it's low on the list. What they propose should work fine for everyday usage.
Users browsing this forum: DuckDuckGo [Bot] and 2 guests
